Posted by Brian Dickinson 1 on 04/06/2023 19:16:47:
Got home yesterday and as soon as we had packed all our stuff away I shot off into the workshop. Looking through my volumes of ME the 1980 series was missing so I ordered the plans for the warrior engine that was on flea bay only to find the series later on. Never mind at least I have a copy and the words to go with them.
I had the parts cut and machined for a 80mm dia boiler so in an hour or so turned up the formers to bend the boiler end plate to. It might be on the small side for the tug I intend building – time will only tell.
Keith Appleton has some great videos on steam engines for boats so I have been watching them with great interest.
So it looks like the build is on. It will be a mad panic to get things underway as in three weeks i get repairs to my shoulder done so I will be out of action for 8 weeks after the 23rd June. I have seen one legged pirates but not one armed ones. Only Nelson.
looking forwards to visiting Trevor to look at the hull for suitability.
Bri
Edited By Brian Dickinson 1 on 04/06/2023 19:18:50
It's not the size of the boiler that is important, it is the size of the burner that is important. The boiler is simply a reserve of energy. What is important to provide the energy needed by the engine to drive the boat is the capacity of the burner. The process I suggest when planning a model should be something along the following lines:
1) Select model you want to enjoy building.
2) Select suitable propeller bearing in mind scale looks and performance.
3) Select an engine capable of turning that propeller at an appropriate revs.
4) Select a burner that can provide sufficient steam to keep the engine supplied at full load.
5) Select a boiler that will fit within the reserve ballast of the model bearing in mind all the auxilliary gear, while giving a suitable buffer for fluctuations in engine use. You can compromise on the burner size if you have sufficient reserve of capacity in the boiler to cover anticipated bursts of full power. You can also compromise on boiler size by including a feed system however then your burner has to be capable of producing enough steam for the engine, plus heating fresh feed water. You will also potentially have less of a buffer so pressure fluctuations may be greater, to the point of affecting engine performance.
6) Finally you need to consider the fuel arrangements to meet the demands of the burner. Gas cooling effect plays a big part in many models especially where a large burner and a small gas tank are fitted. Don't forget, according to the regulations, your gas tank must run out before your water supply.
As I said only a suggested thought path.
A 3 1/2 inch boiler should be fine for your project. Only yesterday I tested a plant with a 3 1/2 inch horizontal centre flue boiler in a Mountfleet Cruiser tug, which is 46" x 12" and 40lb displacement. It also had a feed system to extend duration. It performed beautifully.
