spur gears
spur gears
Home Forums Scratch build spur gears
  • #21238
    james smith 1
      @jamessmith1
      I NEED TO CONTRA ROTATE THE PROPS ON MY 1″–1FT MTB AND AM HAVING DIFFICULTY LOCATING SPUR GEARS
      APPROX SIZE
      50m/m DIA
      6mm THICK
      6-8 mm BORE
      I DID FIND A COMPANY IN WOOTTON BASSETT, WILTS BUT HAVE NOW LOST THEIR ADDRESS ANY HELP WOULD BE VERY MUCH APPRECIATED
      #6569
      james smith 1
        @jamessmith1
        #21241
        Telstar
          @telstar
          Hi James   try RS components   http://uk.rs-online.com/web/, they do have a mail order site somewhere  however if you go to the above site and search spur gears they have a large stock
          cheers Tom
          #21242
          Mike Pendlebury
            @mikependlebury45959
            Best place for the gears you want is HPC Gears in Chesterfield.
                         http://www.hpcgears.com
            If you can’t get what you want there, then it doesn’t exist!!!
            Mike
            #21245
            60watt
              @60watt
              It’s not what you asked for but the 5.5 Mb pdf download  shgmodels catalogue    Has moulded nylon gears on a brass hub with grub screw.The .75 module ones on page 26 are described as 2mm bore but I could swear they were 2.3mm.
              #21268
                HPC is the place, I bought some gears from them for the winder on my rubber band boat. The little book/catalogue they have has to be seen to be believed.  Ashley
