Spark Ignition Large Huntsman
Home › Forums › All things floating › Spark Ignition Large Huntsman
  • #3452
    Boy Shep
      @boyshep
      #23830
      Boy Shep
        @boyshep
        Has any one built a big huntsman and installed a big motor
        ie 26cc or bigger
        I have just got hold of 48 inch kit and want a easy life with reto look but
        easy start motor ive had to many years of glow plug motors LOL
        Any ides would be good on running rear etc
        Cheers
        David
        #23833
          Hi David
          I have a 48in Huntsman, an old wooden version and I have fitted a pull start strimmer engine.
          The engine just fits in the centre section but you loose the depth of the open cockpit as it ends up being full of engine, I also had to fit the engine backwards (ie shaft pointing to the bow) because there is not enough overall hull length for the engine and propshaft in a traditional setup.
          The model sits low in the water but goes like a rocket (60mm prop)
          There are smaller 2 stroke engines such as the “Little Wonder” from a hedge trimmer but they are hard to find, some chainsws have smaller engines and they are perfect for a 4ft hull, try trawling through fleabay for suitable units.
          Hope this helps
          Boy Shep
            @boyshep
            Hi
            Thanks for details can u send me any pics
            i will prob fit a zen 26cc as i already have 2 of them in other offshore cats i own
            I look forward to running bthis next year as i had one 20 years ago with a ed hunter in it
            showing my age lol
            Cheers for help
