servo traval
servo traval
Home Forums Scratch build servo traval
  • #17019
    Brian Astall
      @brianastall30747
      hello chaps,
                         i have a problem,how do i get 1 1/2" traval from a bog standard servo.i,m building EGRET, the one were the wheelhouse go,s up and down.cant work that bit out.HELP!!
      Brian A.
      #17027
      Kevin Bellman
        @kevinbellman86047
        Hi Brian
        I’m afraid I dont have the answer but one gizmo that might help is the new P96 ServoMorph from
        Action R/C Electronics quote " can stretch a standard servo to rotate nearly 180′ "
        http://www.action-electronics.co.uk/home.html
        Just a thought
        longshanks
        #17194
        JC Uknz 1
          @jcuknz1
          This problem is solved by sailing boats by having an arm on the end of the servo arm to increase the radius and the amount of travel at the tip to haul in sheets. The question is do you have room in the model for such a thing? You may need to get a grunty servo for the job.
          It is a question of leverage and if the servo is one inch from the pivot anchor/hinge and the object to be moved is three inches then it will be moved three times the servo’s movement.
          Don’t know what EGRET is sorry
          http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2690/cam_on_servo.GIF
          #17250
          Brian Astall
            @brianastall30747
            Hello Longshanks, thanks for the Action tip,have got the morph and it does what it says but the push rod bends.will keep trying.Thanks,
            Brian A.
            #17251
            Brian Astall
              @brianastall30747
              Hi  JC Uknz,
                        thanks for your reply, will try the cam idea,sounds like it may work without bending the pushrod.
                                         Brian A.
              #17270
              Tony Bell 2
                @tonybell2
                Hi Brian,
                 GWS make a 1turn sail servo for £14 see spec on my sail servo comparison chart.
                 Tony
                #6516
                Brian Astall
                  @brianastall30747
                  or other method
                  #24462
                  Robert Walters
                    @robertwalters31200
                    High Brian, I am curious, what kind of boat is the” EGRET” that the Wheelhouse goes up and down
                    I am working on a Pusher Tug,(with a fixed wheelhouse) and I know that out there there is a set of plans for a Pusher Tug that the wheelhouse rises and falls, but I dont know what company does the said plans, can you or any other modeler help me with this
                    #24465
                    Pierre
                      @pierre
                      Hi Robert
                      EGRET is a plan published by Model Boats about 10 years ago, plus or minus a couple of years – I’m not sure of the exact date. I’m sure a search of the archives would bring up something.
                      It was a plan of a  Rhine river pusher tug with an adjustable wheelhouse – designed to cope with low bridges I guess.  If I recall correctly the plan was fairly simple, designed to be built in styrene, basically a floating box, though the wheelhouse mechanism was quite ingenious.   I know I have the plan and the article somewhere in my impeccable (?) filing cabinet, so if you’re really desperate, I could dig out the exact year or even send you the plan.
                      Hope this helps
                      Pierre
                      #24484
                      Robert Walters
                        @robertwalters31200
                        Pierre, you are a gentleman, the tug I am building is in fact named “PIERRE BROUSSE” it is a Pusher like the “EGRET” (thanks to you, for letting me know that) but has a fixed wheelhouse, and I would like to improve the design of my model with a raiseing wheelhouse or Bridge.So if its no trouble to yourself I would very much like to either get the plan number and the date it was purchased by you for me to try and get a copy or failing that receiving a copy of the said plan from you.
                        Once again thanks for the prompt reply, hope to hear from you again.
                        Pierre
                          @pierre
                          Hi Robert
                          Have sent you a private e-mail requesting your postal address.
                          Pierre
                          #24491
                          Peter Fitness
                            @peterfitness34857
                            Brian, is the pushrod supported? Depending on its length, it may need to be to stop it bending.
                            #24505
                            Pierre
                              @pierre
                              Hi Robert
                              The plans for Egrete were published in MB in May to June 1988 – I was out with the dates somewhat.!  If you want them, send me a private e-mail giving me your postal address.
                              Pierre
