Sealing balsa wood
Sealing balsa wood
Home Forums Beginners Sealing balsa wood
  • #34997
    oldsalt3
      @oldsalt3
      Hi everyone,
      Can you please give me some tips on the best way of making a balsa wood hull watertight before painting.
      Thank you in advance
      Dereck
      #2149
      oldsalt3
        @oldsalt3
        #34998
          See reply #8 from "FLJ". It's not the only method (there are hundreds) but it works. **LINK**
          Tissue is "Modelspan" and dope/sanding sealer can be obtained from most decent model shops.
          Paul Freshney
            @paulfreshney24971
            In June 2012 Model Boats magazine, page 33, Glynn Guest describes how he finishes a balsa hull (within his Triune Free Plan article). All his balsa models over the last 30 years have been finished in much the same way, so his method must work!
            But as Dave M says, there are alternatives.
            Paul Freshney
            Editor of MB.
            #35005
              I generally use copious amounts of sanding sealer, thinned a bit to aid penetration (to waterproof the actual wood), followed by nothing more than paint. Thin ordinary grey undercoat down, acheives the same thing. If you want to harden it, I could recomend Eze cote resin and fine glass cloth as yet another method. Everyone has their favourites.
