S.L. Dolly 1850 Windermere Steam Launch
Home Forums Scratch build S.L. Dolly 1850 Windermere Steam Launch
  • #124607
        Hi All
        A few more pictures.DOLLY 9DOLLY 5DOLLY 6DOLLY 7DOLLY 8DOLLY 13DOLLY 10DOLLY 11DOLLY 12
        #124609
          Hi All
          Dry test fit motor, ESC, prop shaft and home made brass rudder.
          HarryDOLLY 15DOLLY 14
          #124616
            That should be an interesting model when done Harry.
            Good move using the geared motor, you should be able to get really good low speed power on that.
            I used one on my London steam two decker, and you can get the prop turning over really slow but very smooth.
              Nice planking job, especially around the stern, which looks like quite a challenge.
              #124634
                Hi All
                I am trying to do full lenght planks on the boat, but three areas will be short sections.
                I love the Ikea wooden blinds, stronger than balsa and a lot cheaper!!!
                My Aliexpress 63mm blade bench saw is getting a workout !!!!
                HarryDOLLY 18DOLLY 16DOLLY 17
                #124648
                  As others have said, an interesting build Harry, and coming on well.
                  Can you use buff card though next time, as I wasn’t ready with my sunglasses!
                    Hi All and Chris
                    THe 20 pack of Manilla Folder does not have buff, only blue, yellow,green, purple and pink !!!
                    I am using my sunglasses outside today, 35C and only 32C tomorrow !!!
                    Great day for painting !!!
                    Just more planking plus CAD decking ready for real plywood deck with standard coffee stick planking on top.
                    HarryDOLLY 19DOLLY 22DOLLY 20DOLLY 21
                    #124689
                      Hi All
                      Uncoated the hull and started on the floor panels.
                      HarryDOLLY 23DOLLY 29DOLLY 24DOLLY 25DOLLY 26DOLLY 27DOLLY 28
                      #124693
                        That stern section is as beautifully smooth as a fibre glass hull.  You would have no idea that not only is it a plank on frame construction but they are all full length planks.  It is a bit of a shame that not everyone who looks at it will realise the work and skill that has gone into its construction!
                        It reminds me of listening to two judges at a Harrogate Model Engineering Show many years ago who were looking at a model that had been built from scratch by making a wooden plug from plans, then a mould, then laying fibre-glass into the mould to produce the hull.  The judges tapped the hull, realised it was fibre glass and so declared it a ready made hull!
                        Beautiful job.
                        #124706
                          Hi All
                          Making the flooring in section halves so I can get the ballast hinden under the floor.
                          The floor is unstained and stained coffee stir sticks which I will use for decking as well.
                          Also started on the cabin.
                          HarryDolly 39Dolly 30Dolly 31Dolly 32Dolly 33Dolly 34Dolly 35Dolly 36Dolly 37
                          #124716
                            Hi All
                            A bit of a dry fit day for decking plus finished the cabin roof.
                            Looks like all the bits fit in the boiler area, but the 3S Lipo battery will be changed to 2S 1800 mah.
                            HarryDolly 40Dolly 45Dolly 41Dolly 42Dolly 43Dolly 44
                            #124717
                              I must admit Harry a 3S sounds a bit fierce for that model.  You’ll be able to have a figure water skiing behind it though!
                              #124719
                                Hi Richard
                                Totally right, steam launch knot a destroyer !!!!
                                By dropping back to 2S I drop about 650 rpm on MFA info sheets.
                                #124722
                                  Hi All
                                  Just cracking on with seats and started decking !!!
                                  HarryDolly 46Dolly 56Dolly 48Dolly 47Dolly 49Dolly 50Dolly 52Dolly 51Dolly 53Dolly 54Dolly 55
                                  #124723
                                    Hi All
                                    The side walks have been a bit of a pain as not shown on the plans.
                                    So a bit of free design from me !!!
                                    HarryDolly 60Dolly 57Dolly 58Dolly 59
                                    #124724
                                      Hi Harry,
                                      Your making a cracking job of the launch 🙂 I especially like the different colour timber your using , it brings her to life, keep up the good work .
                                        Hi Ray
                                        The decking is my standed coffee stir sticks with the darker ones stained with walnut stain.
                                        #124740
                                          Hi All
                                          A bit more work and started painting.
                                          Red Oxide with dark blue for the sides and I cut back the white line at the bow because it looked a bit too much on the plan.
                                          HarryDolly 66Dolly 61Dolly 62Dolly 63Dolly 64Dolly 65
                                          #124753
                                            Hi All
                                            Well it’s starting to look like a boat !!!!
                                            HarryDolly 67Dolly 72Dolly 68Dolly 69Dolly 70Dolly 71
                                            #124758
                                              Hi All
                                              Just down to the steering to do !!!
                                              Also a rename to Jasmine, our second great granddaughter !!!
                                              In gold lettering of course !!!
                                              HarryDolly 78Dolly 73Dolly 74Dolly 75Dolly 76Dolly 77
                                              #124763
                                                Hi All
                                                All finished, just re- ballasting after the first run.
                                                HarryJasmine 3Jasmine 1Jasmine 2
                                                #125080
                                                  Hi All
                                                  I have taken about two thirds of the lead out of the stern and the boat sails at the water line.
                                                  It’s no rocket, but just works up to a small bow wave at top speed on 2S Lipo.
                                                  I had a 3S Lipo about the same size which I may try just for the hell of it!!!
                                                  But I am super happy with the boat, but great granddaughter number one wants a boat with her name on it !!!
