Reducing 12V to 6V
Reducing 12V to 6V
Home › Forums › Scratch build › Reducing 12V to 6V
  • #7010
    David Marks 2
      @davidmarks2
      #57997
      David Marks 2
        @davidmarks2
        I am currently building a version of Glynn Guest's UTE. The batteries for the motor are twin 12v to be wired in parallel. I wish to add a searchlight, which operates at 6V. Is there a device on the market which I could use to step-down the voltage? Or would it be easier/cheaper to install a separate 6V battery just for the searchlight. My thanks in anticipation.
        #57999
          Any one of these will do the job, David **LINK**
          David Marks 2
            @davidmarks2
            David – Many thanks for your prompt response. Is it me or do these items not appear in the Component Shop catalogue?
            Regards – David Marks
            #58003
              There are some items on the website which don't appear in the catalogue – I've no idea why. Maybe timing?
              Barry Martin
                @barrymartin11489
                I have used a JP "Li-Po" regulator, obtained from my local model shop, which reduces from 12v – and more- to 6v. These are designed for aircraft flyers, who often use well over 12v. There is another version which reduces to 4.8v, and that has been useful on my "paddler" to slow the paddle speed down.
                #58243
                David Marks 2
                  @davidmarks2
                  Barry – Thanks for that information. For the current build I have now purchased a UBEC from Component Shop following information supplied by Dave Milbourn. However, I will remember if I need another unit. I know my local model shop stock JP (Jim Perkins) products or will get them within a few days.
