James if you need aircraft for your carrier Trumpeter do an excellent range in 1:350 scale ideal for the carrier and come in 10 to a box.I was considering building it at 1 time but things went wrong atthe cronstruction stage when i tried to use the Solar Film stuff use put on with an iron or hair drier so dopey here used an iron and made right dogs testies out if it so now its sat on a shelf util i get around to using a power sander to get rid of the mess i made of it !!!!!!!!!!!
good luck Andy from Cardiff
ps hello grumpy
