Rails
Rails
Home › Forums › Scratch build › Rails
  • #10232
    Sam Nicholls
      @samnicholls81892
      Hello.
      I have almost completed my first scratch build. However, before it is entirely complete I would like to add railings around the perimeter. How is this done? Is it a case of buying small metal rod and joining somehow? If not, how can this be achieved?
      Thanks,
      Sam
      #10267
      Guido Sambucetti
        @guidosambucetti90794
        Basically it all depends on your skill and the scale of your model. You can do it with metal rod but it must be scaled down so it doesn´t look too cumbersome, besides it will need some soldering which is tedious and requires some practice.
        There are options, however. Several manufacturers sell stanchions in various sizes and shapes and all you need to do is to join them with brass rod. I build my models in 1:72 and use commercial stanchions that save me a lot of work and are of very good quality (mind I have never entered a contest!). I use cyano to glue the rod to the stanchions.
        I am away from home now, but if you can wait a couple of weeks I can send you the address, I remember I found it in Model Boats several years ago.
        Cheers,
        GUIDO.
        #10380
          Hi Sam
          I have found that using brass rod for the rails and split pins for the posts can make great railings, as the rod and pins come in different guages you can cover most scales.
          You can solder the joints if you wish but you can also use superglue,the brass is easy to bend especially if you use a former such as a coin,a piece of tube or even the shaft of a house key.
          #10381
          Guido Sambucetti
            Hi Sam,
            Here´s the promised address (better late than never, I expect!):
            James Lane (Display Models)
            30 The Broadway
            Blyth, Northumberland NE 24 2PP
            Phone 01670 352051
            He makes round stanchions in 1:128, 96, 72 and 24, but other scales are available too. Besides, they are much cheaper than turned brass stanchions.
            Good luck!
            #10387
            Jake Knight
              @jakeknight71345
              hi sam,
              you can buy some stanchions in a pack of 10 for £2.oo from
              http://www.alwayshobbies.com
              hope it will help
              #10397
              DickyD
                @dickyd
                James Lane is the man for stanchions 01670 352 051
                #16932
                Roy Parkes
                  @royparkes
                  Is there an Email contact for James Lane, the Hobbies are to long?
                  #16933
                  DickyD
                    @dickyd
                    No Email address I’m afraid, just the phone number.
                    #6377
                    Sam Nicholls
                      @samnicholls81892
