Proxxon DSH/E Fretsaw
Home › Forums › Buy/Sell or Trade › Proxxon DSH/E Fretsaw
  • #31844
    Steve Lindley
      @stevelindley34098
      My Proxxon DSH/E Fretsaw is for sale at £135.
      I’m afraid it’s too heavy for me to pack and send by ParcelForce or other carrier, so you will have to collect from Andover, Hampshire. I am likely to be driving up the M1 to Leeds within the next two weeks, so that is an alternative for a meet.
      I bought it new and have used it on just a handful of occasions. There are quite a number of spare blades included. Various tooth pitches and both pinned and clamp style.
      FEATURES
      1 -Free moving blade chucks accept both pin and plain end blades.
      2 – Practical quick release lever for quick blade changes (important when cutting internally). The slender over arm facilitates a clear view of the work piece.
      3 – Air blower with adjustable nozzle provides clear visibility of work piece and cutting line.
      4 – Two parallel swinging saw arms made of die-cast alu with ball-bearing direct drive.
      5 – Rotary knob for basic adjustment of saw blade tension.
      6 – 400 mm throat.
      7 – Sturdy die-cast aluminium table 360 x 270 mm tilts up to 45° for mitre sawing
      8 – Machine base of cast iron with rubber feet for vibration-free operation and stability, may also be screwed down.
      9 – Powerful special motor with electronic speed control yields constant speeds under load.
      The ideal machine for tool and die making, model building, toy repairs, puzzle sawing, architectural work, antique restoration, etc. Absolutely safe: ideal for schools and training centres.
      SPECIFICATION
      Cutting capacity in wood 50 mm, plastic 30 mm and in NF metal 10mm
      Table size 360 x 270 mm. Length 53 cm, height 30 cm, width 27 cm.
      Motor is 220 – 240 V 200W 50/60 Hz
      Electronic speed control 200 to 1,400 rpm
      Stroke 19 mm, 400 mm throat with 50 mm maximum depth of cut or 25 mm at 45° table tilt
      Complete with 5 each coarse and fine blades and T Allen key
      Weight approx. 20kg
      #8873
      Steve Lindley
        @stevelindley34098
