Prop and Motor for Lochmor
Home › Forums › Scratch build › Prop and Motor for Lochmor
  • #29448
    Sundance
      @sundance
      I am relatively new to model boats – my first was a tug from a free plans and this is my second boat.  I am building MV Lochmor ( a Calmac ferry), scale approx 1:35, plank on frame, to a plan from Nexus.  The boat is 860mm long, beam 227, and 5.78kg.  The plans suggest 2 no. monoperm motors and a handed pair of 50mm four blade brass props.  At the model boats show a supplier recommended a 540/1 motor geared 2:1 for this propeller, however he suggested that current practice would be to use a smaller prop ( to scale ) with a direct drive motor.  Unfortunately I have been unable to establish the original prop size.  Does anyone have any thoughts on what would be appropriate for a model of this size / type?
      ( I’ll post a photo of the hull so far when I work out how to do this).
      Many thanks,
      Gavin
      Edited By Sundance on 15/01/2011 21:15:44
      #6694
      Sundance
        @sundance
        #29451
          I would start with 35mm 4-blade props. If you want to use direct drive then perhaps a pair of Mabuchi 555 motors on 12v. This will give plenty of power. If you’re inclined towards just pottering around then 30mm 3-bladers with 385 motors would possibly be adequate (7.2v maybe?).
          Sundance
            @sundance
            Many thanks.  I assume that would be a brass propeller?
            Gavin
            #29486
              O yes – plastic props are only for toys (head down now – wait for incoming missiles!!)
              Raboesch Type A or Prop Shop Scale-type are both suitable, but sit down before you see the price….
              Sundance
                @sundance
                I’ve been looking at the Raboesch Type A so I know what you mean!
                #29519
                  DM. Nowt wrong with plastic props !! (for certain applications)
                  However… why do they only do them in black?? or worse, red?? why not Gold colour…and why such a shallow pitch?
                  I have a 35mm Black plastic on Berengars Island class patrol boat (some sort of 500 on 6v) and its fairly pitchy, and has a longer boss point than usual, no idea of the make or where I got it. Shame, because it works really well. Plastic COULD be good, as the blades would be thin and sharp..but….
