Plastic Covering Materials
Home › Forums › Scratch build › Plastic Covering Materials
  • #14097
    Revell Walker
      @revellwalker82816
      Hi all, before I do this, I was wondering if any of you have tried covering materials such as Monokote as a hull finish, particularly on balsa and plywood. I’ve seen it done once so far, but I’m wondering about long term maintenance and water intrusion. I’m considering pre-finishing the hull with Balsarite so the film sticks better to the wood and offers some measure of fuel proofing. I figure if float plane pontoons are done this way, why not a whole hull? Your thoughts on this matter are appreciated. When it comes to using fiberglass for a finish, I’m rather lazy.
      #14202
      Len Ochiltree
        @lenochiltree67043
        Hi Revell,
        I have never used anything exept wood primer/undercoat then topcoat and have had no problems with water getting in.
        Len.
        #6470
        Revell Walker
          @revellwalker82816
          Using Solarfilm, etc for a balsa hull
