plans for ships boats
Home › Forums › Scratch build › plans for ships boats
  • #21333
    Phil
      @phil
         I am building a 48 scale model of King George V (1940).  The hull is completed and I am presently working on the superstructure.
      I am having difficulty in obtaining plans for:
      Crane
      45 foot hard chine fast motor boat
      45 foot motor launch (clinker)
      25 foot fast motor boat
      Someone suggested Norman Ough might have plans but I have not been able to track them down.
      Does anyone know where plans might be available, or know of someone who has built a model who might be able to provide copies of the plans.
      Phil
      #6570
      Phil
        @phil
        #21335
          Hi Phil,
          The Norman Ough plans went to David MacGregor plans for quite a long time, but when he died, I believe they went to the Great Britain Trust.    As far as I know, they are not accessible to the public at the moment, but that may have changed.   Worth asking them anyway.
          I have had one or two Norman Ough drawings and feel that although they appear at first glance to be hightly detailed, they do, in fact, leave a lot off!
          Phil
            @phil
            Thanks Bob.  I have heard similar comments about the drawings.  I have found an address for the Trust at Great Western Dock, Bristol.  I might write over.  I am in Australia.  Do you know if that is a current address?
            Phil
            #21350
              I don’t know the correct address, but I am sure that would find them as the Great Britain isn’t going anywhere.    You may even find it on Google.
              Rick Fryer
                @rickfryer11539
                Phil,
                Have a look on John Lambert’ site http://www.lambert-plans.com/encom/index.htm
                – some ships’ boats under “Warships – Miscellaneous”
                Rick
                Edited By Rick Fryer on 07/06/2009 15:08:30
                Edited By Rick Fryer on 07/06/2009 15:09:15
                #21358
                Phil
                  @phil
                  Thanks Rick.  Checked him out.  No large boats.
                  Phil
                  #21359
                    Phil
                    The sea plane recovery crane would have been built by a company called Stothert & Pitt this engineering company built most of the cranes for the Royal Navy.
                    The company still exists although part of the Clarke Chapman group try this link
                    you might be able to get some information from their company archive.
                    There is also a fun to watch computer sim of the battleship on this site in which you get a quick look at a crane
                    There are also some quite good blueprints of the King George on
                    but you might need a CAD system to manipulate them.
                    The larger of the ships boats were probably built by Scott-Paines British Power Boat Company, try this link.
                    Edited By The Fat Controller on 08/06/2009 06:51:11
                    #21370
                    Francis Macnaughton
                      @francismacnaughton39461
                      Phil,
                      That will be some model in 1/48th!  I saw a PoW in that scale a while back and the owner sits/lies inside it – is yours conventional Radio Control?
                      As to the Norman Ough drawings, they were printed in small scale in Model Boats around 1970/71 and I have the page for the 25′ Motor Boat to hand – it would be adequate for scratchbuilding in that scale.  I could forward a scan. Others I have are 32′ Cutter and Motor Cutter, 27′ Whaler, 50′ Steam picket Boat, 42′ sailing Launch and 36′ Motor Pinnace.   The other items you were after may well have been covered but I just don’t have the full series I’m afraid.
                      Francis Macnaughton
                      #21429
                      Phil
                        @phil
                        Many thanks for all of the information you have given me.  I will be checking it all out.
                        Phil
                        #21430
                        Phil
                          @phil
                          Francis
                          Once I get a bit further along, I hope to put some photos up.
                          I have emailed you directly.  Thanks again Francis.
                          Phil
                          #21434
                          John Haynes
                            @johnhaynes15363
                            Norman Ough did not cover any other boats , apart from those mentioned . However , some details are in the Anatomy of a Ship series.
                            Also , on the topic of cranes , although on first glance these appear to be the same on each ship , their construction detail do differ .  When I considered PE ‘ing a set  I gave up when research meant I could only make one , but which one to choose ?
                            #21932
                            Foeth
                              @foeth
                              I have a drawing of one 45ft fast motor boat lying around which I got through John Lambert, but not an official Lambert production drawing. I could make a small scan. I received most of my drawings through Lambert.
                              The only one I’m really missing is the 42ft motorized barge. I’ve made small 1/350 models of a series of small boats and launches using their lines drawings Link
                              Edited By Evert-Jan Foeth on 09/07/2009 13:30:14
                              #22228
                              Phil
                                @phil
                                I would be interested in seeing what drawings you have of the 45 ft fast motor boat.  If I give you my email address, what drawings would you be able to provide?
                                #22229
                                Foeth
                                  @foeth
                                  Top/side view with some dotted interior lines, two transverse views,  linesdrawing.
                                  #22783
                                  Phil
                                    @phil
                                    Foeth
                                    I would appreciate it if you could scan and email me the drawings.  I have sent you my email address.
                                    Phil
