Netting around the cage on an airboat
Home Forums Scratch build Netting around the cage on an airboat
  • #16461
    Who Boot
      @whoboot
      I have built a model of an airboat, as featured in a plan in Model Boats magazine September 2007. The model is called Skimmer by its designer Glynn Guest. If you go no further than the plan with your build then the cage around the propeller is completely adequate in terms of safety for the model, but I would like to detail it a bit further through enclosing the propeller even more. However, i don’t know what I can use as a netting to put on top of the framing (made out of thin steel rods). I could do with something like chicken wire, only that the holes are much smaller. The scale of the airboat is about, i guess, 1/10 to 1/12. Rather than mess about with trying to use thread or fishing wire I would like if there was something more ‘one piece’ i could just fit over the framing. Can somebody please suggest something?
      #16467
        Haydn, there are various other types of metal mesh available, in  square patterns, rather than hexagonal like chicken wite. The wire is a bit thicker too so it stays in shape better. I have some at home now with holes about 1/4" in size, but they go up in size from this . Garden centres should stock it. Ashley
        #16474
        Len Ochiltree
          @lenochiltree67043
          Hi Hayden,
          This is what I used,its the left overs from the Cat Pens when I used to foster cats for the Cats Protection Charity.It was bought at a Garden Centre.
          Len.
          http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2627/Fishtail_Rudder_&_Air_Boat_Nov_07_003.JPG
          Hi Hayden,
          #6507
          Who Boot
            @whoboot
