my new model i am converting
Home Forums Gallery my new model i am converting
  • #20129
    mick
      @mick
      i bought this boat on ebay and i am converting it to a r a f sea plane tender
      pictures on albums site i will update as it goes on
      Edited By mick on 10/04/2009 20:59:56
      #8539
      mick
        @mick
        #20161
          Mick, good luck with that, it seems to be a good boat to start with..is there a prop shaft fittted??  have to watch out if its an old hull it might have a 4Ba shaft fitted and not a 4mm one !  How big is it and did you have any thoughts on motive power?  Ashley
          #20168
          mick
            @mick
            hiya ashley
            its is all done shaft was fitted sorted i put in a 600 motor and a two bladed prop40
            just finished the well deck and mast  the boat was crossed planked and was built
            for ic use had to fill in holes in the hull but all done i am going to run it on 7.2v
            buggy packs two in parallel and a esc but still work in progress check the latest
            photos mick
          Home Forums Gallery Topics
