MTB
MTB
Home › Forums › Scratch build › MTB
  • #13556
    Barry Minter 1
      @barryminter1
      I have built the Vic Smeed designed Thornycroft MTB, the plans from MAP. The boat is designed for a Taplin Twin diesel but I wish to use electric power. Being new to the game of electrics in a wooden hull some 3 foot long I would appreciate some advice/help in using one motor or two and the type of motor it /they should be. Power will also come into the equation and also the facility for reversing.
      Any help from anyone would be greatly appreciated as nobody here in Potugal seem remotely interested in the hobby.
      Barry.
      #13577
      mick
        @mick
        hiya barry mick here
        first you want to decide if you want a single motor setup or twin shafts twin rudders and twin
        electric motors and if you want to use 6v or 12v setup  the differeent motor setup will be
        decided on this ? there are a lot of motors out there so it should be no problem
        hope this of help mick
        #13578
        Barry Minter 1
          @barryminter1
          ‘evening Mick,
          Thanks for that.
          I have  twin rudders fitted from the transom so I take it the single prop was a bad idea!!! I shall have to fit twin props in that case. What are the advantages and disadvantages of 6 compared to 12 volts?
          #13579
          mick
            @mick
            hiya barry most of the m t b i have worked on are twin motors twin shafts as you said you had
            twin rudders the range of motors is depends on the speed and the battery setup plus what room
            you have in the hull i have seen them with all sorts of motor and battery setup s but keep up
            the good my m tb has twin 545 motors running on a single e sc and a 6v 4amp battery
            but if you use bigger batterys and bigger motors hope this helps mick keep asking the
            members as they will have all sorts of ideas
            #6455
            Barry Minter 1
              @barryminter1
              Vic Smeed Design
