Marking from plans
Marking from plans
Home › Forums › Scratch build › Marking from plans
  • #39485
    wayne quigley
      @waynequigley28540
      Hi guys
      my newest ship is nearing the end my son would like a new boat.he has decided on the Glynn Guest UTE plan no mm2079..
      how do you guy who build from plans transfer the plans to the wood with out cuting the plan up,I am thinking tracing paper, and then turning tracing paper over and redrawing to transfer pencil lines to wood.
      is there any better way.
      Cheers
      Wayne
      #6867
      wayne quigley
        @waynequigley28540
        #39486
          Hello Wayne
          Place the plan over the wood and using a bradawl, prick out the item`s profile.
          Remove the plan, then join up the dots!………It`s that easy
          wayne quigley
            @waynequigley28540
            thanks I dont usualy use plans.I have made one of Glynns Models before but that was some time ago
            #39489
              Wayne
              One way is to photocopy the plan in sections and stick the pieces together. Another way if you have a scanner is to scan the plan in sections, print and stick the sheets together.
              Keith Long
                @keithlong89920
                Carbon paper between the plan and the wood, trace over the plan lines with the end of a knitting needle?
                Keith
                #39514
                mark69
                  @mark69
                  Hi Wayne maybe the method l use may be of some help to you . lf you could get you plans photo copied at a printers you can then cut out each part then.. heres the cleaver bit ,,use a PRITT STICK and if your plan requires two of said part just tack your wood together and you can remove yhe paper from the wood after ..ive made lots of models from plans this (mainly aircraft !!!)…..
                  mark
