A little more info about the launch.
The launch is approx 30ft long with a high vertical bow, forward cabin with portholes directly in front of an enclosed bridge, open rear that originally contained a steam engine [later converted to diesel] with a distinctive torpedo stern.
White hull with varnished uppers the boat is built from teak on oak frames.
Last seen it was being converted into a cabin cruiser with a pile of wood reclaimed from a dance floor, sadly the new owner decided to fit an outboard motor and cut a 2ft hole through the bottom of the hull [near the stern] to accommodate it.
Its a long shot but if it still exists then it is very possible that it is still on the Bridgewater.
The stern looks like the one on this launch [the stern can also be called Dovetail or Draketail]
