Looking for plans
Looking for plans
Home › Forums › Static modelling › Looking for plans
  • #12446
    michael wilkinson
      @michaelwilkinson87978
      hi does anybody know if these plans are still available? does someone have a set that they no longer require? i would willingly cover postage and reprograhic costs.cheers….mick
      #12729
      Mike Wingfield
        @mikewingfield34114
        Mick
        Are you after copies of the drawings for the kit by Victory Models, if so I can probably help you
        Cheers
        Mike
        #14601
        Pete Danks
          @petedanks14219
          Mick,
          a belated answer, I’ve just re-discovered the site. All I did for Fly, a very long time ago, were drawings of the rigging, not the hull. I worked directly from the original Admiralty draught from the National Maritime Museum, with detail added from the diagram in Fast Sailing Ships by David MacGregor. I’ll copy the rigging drawings for you, and MacGregors diagrams if you need them, just e-mail me your address at  /forum/smilies/tongue_out_smiley.gif[/img][email protected]][email protected]
          for some reason the site corrupts my e-mail address to the above. My e-mail address is the last bit, after the ]
          Regards,
           Pete Danks
          #14830
          michael wilkinson
            thanks for your reply pete.i have a full set of your plans for the sloop of 1776,hopefully this will form the basis of the next project.i have an improved model of caldercrafts snake to finish first,then i can start!!!!
            i can always obtain  a copy of the lines for fly from the nmm  at a future date. i think with the reference material i have and the sloop rigging plans i should be able to work out the rigging for fly as it is a fairly simple affair.
            can i take a brief moment and thank you for your articles over the years in model boats , myrmidon was truly inspirational!!
            regards….mick
            #5674
            michael wilkinson
              HMS Fly by Peter Danks
