kms bismark
kms bismark
Home › Forums › Scratch build › kms bismark
  • #92133
    chris fenerty
      @chrisfenerty25956
      hello everyone,
      does time change with scale,
      my ship that i am constructing is 2.6m long. the turret is suppose to do a 22 second full rotation in real life, so because my ship is a lot smaller will the scale time change. i intend to use a hollow shaft stepper motor with a 1.8 deg step controlled by a micro stepper so i can get smoother travel, the hollow shaft allows me to raise and lower the guns through the use of another actuator.
      the radar rotation speed is also in question.
      any feedback will be very much appreciated
      #7194
      chris fenerty
        @chrisfenerty25956
        turret turning speed
        #92135
          Vexed question indeed. I am bound to say that things like turning radars have to look..right…and not necessarily be the correct scale speed.
          BUT
          Can you scale movement? A radar turning at 60 rpm in real life would turn at 60rpm in any scale?
          My feeling is that nice smooth rotation is the key rather than worrying about how fast….as above, I would aim for the same rotational speed as the real thing.
          Another viewpoint…if you made a video of the boat from really close up, so it looked full-size, how fast would you expect to see the turrets rotate??
          chris fenerty
            @chrisfenerty25956
            hello ashley, i intend to use a stepper motor with a built in gearbox controlled with a micro stepper control for smooth movement of her radars, but you can buy motor gearbox units which need less controls for actuation, but i do not know the speed of her radar
            a lot of historical information is hard to find
            #92145
              I can’t imagine the radar turned very fast due to the relatively crude electronics, however, if you were able to find out how fast other contemporary radars turned that might be a start.
              Perhaps bear in mind that if it went very slowly, you would not notice it on the model. Another thing is, who else would know how fast the radar turned? Whatever you choose would be correct….
                As far as I am aware the radar aerial on Bismarck was fitted to the front of the main armament director and would have rotated with it as it trained on the target and not turned independently.
                As far as the main armament and director are concerned I would have thought that 6-10 seconds for 180 degrees on a model would look fairly realistic. The turrets would normally follow the director of course.
                chris fenerty
                  @chrisfenerty25956
                  hello collin,
                  i have found out that the main turrets can move approximately 270 degrees full rotation @ 22 seconds so if i move them a fraction slower no one would ever know, i will peruse my plans again about the radar and firing director.
                  the plans i am using are the actual schematics showing every compartment and it`s use, i had the plans blown up so i could get some detail and realism which a small boat cannot do.
                  if you would like a set of the pdf plans that i have, i could upload them to which ever site you specify so the group has access so they can build their own
                  the tirpitz was the bismark`s sister and my plans say tirpitz and have a scale in the legend
                  #92152
                    I think that in this situation the turning speed would be best judged by eye. Just a happy medium between whipping around and crawling painfully!
