I want to build a Hovercraft, Help!
Home › Forums › Scratch build › I want to build a Hovercraft, Help!
Viewing 25 posts - 1 through 25 (of 41 total)
  • #15415
    Len Ochiltree
      @lenochiltree67043
      I fancy having a go at building a Hovercraft from scratch, the one from Hobby Store the Bell SK5 looks a nice one.
      For those of you that have read some of my postings you will know that I am careful with my cash output.
      So, some questions,   Is the above one OK?  will I have to use Nicads/Nmh I usually use SLAs,
      What run time will I get? How many Channels will it need?.
      How complicated is the Skirt to make,is it glued or sewn?.
      Any advice will be appreciated, also Plans and Photos.
       Regards,
      Len.
      #15417
        Len. There are several model hovercraft sites out there with some good info on them, modelhovercraft.com is one.  I am afraid your SLA battery is out of the question… one was too heavy for my Shorty, and that was only floating and not hovering!. Two channels will suffice for drive motor and rudder, but only if you accept the lift fan being on all the time, otherwise three channels looks like being needed. I suppose you could mix the lift and propulsion motors? The skirt as far as I can see is the tricky bit, ripstop nylon appears to be the material of choice and can be glued according to some previous research. A bit catch 22…the more bits there are to the skirt the more efficient it will be.  The larger the hovercraft the easier in this regard.I am not sure about run time as they require some fairly powerful motors, and weight, hence smaller batteries becomes an issue unless you want to go only slowly ! I also understand that fixed prop and rudder types are difficult to control, rather than a moveable prop or ducted fan set-ups. A nice true scale model is likelty to be even more difficult to this regard.
        ALTERNATIVLEY-as an idea to throw in,  I am contemplating an SRN4, of fairly serious dimensions, but making it only a SEMI-hovercraft… ie a floater with air assistance. It will have essentially a catamaran hull (ish) hiding beneath a skirt and some sort of fan (but nothing too powerful) to blow air underneath. My experience of watching hovercraft is they only really perform on flat surfaces, and as this is likely to be yer usual pond then if it LOOKS like its hovering, all well and good. This gives you "the look" but without an endurance problem and having to worry overmuch about lift and getting the skirt dead right, besides which my spare time is relatively limited.. or is this too much like heresy ?????
        There must be some hovercraft owning chaps out there to rubbish my thoughts……..Ashley
        #15435
        Len Ochiltree
          @lenochiltree67043
          HI Ashley,
           Your Semi Hover sounds the way to go, what a great idea!.
          So far you have designed a plane that doesn’t fly,now you are designing a Hovercraft that doesn’t hover,whats next?.
          Regards, and any more ideas re the non hovering HC will be welcome.
          Len.
          #15442
            Len. You should see my space ship !!!!!      (only joking)
            The skirt seems to me to be the stumbling block on this, but after much thought I am going (eventually) to try a simply tube of ripstop Nylon, constructed by folding a long strip almost in half and sewing along the length…the "almost" means that one side will have a flap hanging over the seam which would be placed at the botttom of the skirt and form the "fingers". Holes will have to be made and reinforced with glue along the inside bottom of this tube to let the air out, AS the really cunning bit to all this is using a  ducted fan unit (available from a shop the website of which i have at work) to inflate the tube, giving it the correct rounded appearance as its in flight. The loose flap may need a bit of gathering in to acheive the correct look, but the theory is dead good. A prototype would be required to get the balance of motor/holes etc etc rougghly right but this can be made with corrugated card box material, a hot glue gun to fix the bits and a quick coat of varnish. Quick and easy. If a semi hoverer is made then there would be nowt to stop you ganging the lift and thrust motors together, as a loss of lift at lower speeds doesnt matter on water. Ashley
            #15443
              ALSO. to be really really cunning, if a few small castering wheels were included underneath (obviously these would be invisible underneath the skirt) then the thing COULD BE DRIVEN ON LAND !  Ah, imagine the looks on those faces as you race across the car park….and splosh into the pond.
              Ashley (feet firmly in the clouds)
              #15450
                Hi Len
                Try http://www.hovercraftmodels.com/RC%20Hovercraft_SK5.htm this is a US site dedicated to model hovercraft.
                Len Ochiltree
                  @lenochiltree67043
                  Hi Paul/Ashley,
                   Thanks for your help guys.
                  Ashley, I had thought of a HC lookalike,building a flat hull then adding a sculpted bluefoam skirt around it covered with black Ripstop to give the appearance of an inflated skirt.
                  I thought about driving a spinning but only decorative Air prop via a pulley an belt take off from the Propshaft,constructive criticism welcome.
                  Your wheely idea,what would propel it forward?
                  Len.
                  #15453
                  Telstar
                    @telstar
                    HI Len
                    I have an old model maker plan for a semi scale free running model SRN1 hovercraft. It is designed to use a 3.5 cc ic motor and is about 40in by 30in  and is made from balsa ( no skirt).
                    If this is of interest let me know
                    cheers tom
                    #15454
                      Len. The air prop would propell the not-hovercraft when on wheels. No problem. I have a plastic toy hovercraft (military sort or srn6) that is as you suggest, a solid skirt and this looks suprisingly convincing going around our fish pond driven only by its air-prop. I think an air prop would be sufficient to propel a solid-skirt floater, no need for a water screw,makes it a lot simpler, and the air rudder is just that, a rudder upside down, so easy as well. I can see lots of hassle trying to link the two, and if you are making that much effort, you may as well go the whole way! You can buy natty ducted fan units all ready to plug in a motor of your choice (there are several sizes and the appear to accept various size motors)). Alternativley, there are some very thin motors out there to spin props without drawing much current, while using a water screw. This was of course the original idea for Shorty, but in the end the wing motors-only Speed 280`s, were so fiesty i did away with the water screw. Ashley
                      #15500
                        Len. Went to the Hovercraft museum at Lee-on-the-Solent yesterday, Saturday, and discovered the secrets of model hovercraft, there being loads of models there. It also explaing the usually miserable performance on anything but a dead smooth surface. The skirt on the majority of them IS just a simple sausage tube, it is fed air to inflate it but it IS NOT vented. This skirt is inflated by the lift fan, but only a small amount of the total air is used, the rest is stuffed underneath the craft in the manner one would think. The inflated skirt, looking like a pukker hovercraft skirt, is used to contain the air and create the cushion, but simply drags along the ground to create the seal, very innefficient and so leading to poor rough-stuff hovering performance( it doesnt actually drag too much, there being air escaping under it). The answer of course is to do it properly and have a seperate finger skirt, or fingers underneath the main sausage, but having seen the complexity of this on one of the larger models that had a pukka fingered skirt, I fully understand why the sausage is the norm ! Besides which, the simple sausage works well enough in most situations. A centrifugal fan also seems to be the preffered lift mechanism, all hand made on those I  saw. So there. I will see pictures of your next week, eh?   Ashley.
                        #15531
                        Len Ochiltree
                          @lenochiltree67043
                          HI Ashley,
                          Glad you had a nice day out.
                          Whats a centrifugal ? fan.
                          Len.
                          #15539
                            Len, Basically its a disc with blades standing on the edge which is spun round. (think of a round model of stonehenge with very thin stones) if you have a cover over the top of this, the air goes in the centre of the dic and gets flung out the sides (hence the centrifuge bit). Think also of a flat shape hairdryer with a hole in the side, a Morphy-richards for instance. This sort of fan gets used in car interior heaters a lot. It produces a good volume of relativly low velocity air, and is generally quieter than a prop or fan. There are few centrifugal fans on the market small enough for model use however, and usually it seems that hovercraft makers have to make their own, which is a fag as they have to be reasonably balanced or they wobble or vibrate, a lot, depending on speed. Computer cooling fans also seem a good alternative and in a handy size but the problem here is mounting the fan on a more powerfull motor. According to more research, only perhaps 25% or the total power needed to get a working hovercraft appears to be needed for the lift, the rest is for propulsion. Propellers in a duct seem to be the next most used device, I am not sure why they dont use ducted fans, as these are available ready made in various power and dimensional sizes and very cheap. Alright, I will give you two weeks to make summat`    Ashley
                            #15557
                              ALSO, instead of all that carving, how about using foam pipe lagging for a fake skirt? comes in 2 or 3 sizes, nice and round and light weight, glues well. i have seen rib`s made of this and it looks ok. Could paint it with acrylic paint instead of nylon as long as your joints were tight,no gaps. Ashley.
                              #15570
                              Mike Davidson
                                @mikedavidson22772
                                Hi Guys50 years ago as a 10 year old, Christopher Cockerel was building his experimental hoovercraft, and my comic, the Eagle had a centrefold showing what this vehicle was all about. I had a thimbledrome aircraft enginewhich I mounted vertically on a sheet of balsa in which I had cut a hole for the air to be blown through to provide the cushion My radio control was a single channel valve driven unit by Electronic Developments (ED) with a sequential escapement which meant that I could only turn to starboard if I turned to port first and waited two marching pacesbefore pressing the transmit key and starting the real turn. Once the air got underneath the sheet balsa base, the cushion was established, and was strong enough to carry the weight of engine fuel radio and batteries. I remember the thing whizzing off down the road totally out of control because the road camber overcame my ducted air control, so take my advice, steering is not at all positive, allow plenty of time to manoevre ‘cos you have NO BRAKES. Good luck, work it out and do it
                                Havefun. Mike D
                                #15581
                                Len Ochiltree
                                  @lenochiltree67043
                                  Hi Ashley,
                                  I am at present making Mark 2 Paddle boat for my clubs yearly competition wich takes place on 14th Sept.
                                  Re the Hover bover,could always build a BIG skimmer?.
                                  Len.
                                  #15590
                                    Hello Len
                                    Oddly enough Model Boat Mag will be covering a skimmer and a hovercraft in next months issue.
                                    Len Ochiltree
                                      @lenochiltree67043
                                      HI Paul,
                                      Yes I spotted that.
                                      Len.
                                      #15617
                                        I like it. Perhaps we could have a think and suggestions on more esoteric (not a dirty word) and unusual models to build. Thats what I like. Makes a change to turn up at the pond with something with a "wow" factor  (another fishing boat or tug does not cut the mustard at teddington).   NO OFFENCE INTENDED TO ALL THOSE WHO LIKE TUGS AND FISHING BOATS. I LIKE TUGS AND FISHING BOATS, ITS JUST THAT THERES LOTS OF THEM>  Before i get another snotty reply post !!!   Ashley
                                        #15633
                                          You young whippersnapper you should be horse whipped for not liking tugs and fishing boats
                                          These models are the very backbone of the model boat fraternity and to be perfectly frank they should be the only models that are permitted to sail on club waters. This modern craze for hovering things is a flash in the pan and should be put down by force if necessary..in fact anyone caught sailing such an abomination should be conscripted into the army where they would learn some respect.
                                          Well Ashley is this snotty enough for you or should I start on politics
                                            Paul, That was so snotty I have been forced to take a large Brandy and rest on the sofa
                                            When ,eventually and if, I make my SRN4 I will only take it out after dark and not tell anyone about it     Ashley
                                            #15654
                                              A busy chap like you should not be drinking brandy and lying down……you should leave that to an expert…..like me.
                                              So send the brandy to:
                                              The Fat Controller C/O Vinnie the editor.
                                                I have been a busy chap, besides drinking, and made myself a prototype SRN4 hovercraft to test the wonderful theory. Hot glue is a wonderful thing for quick constructing!
                                                It is made out of 3mm MDF; the top is flat, there are 4 ribs underneath and a 1" shelf around the bottom to stick the skirt on to, with cardboard sides about 3 inches deep. It is 19" by 30" overall, skirt sticks out another 3/4"-1". It is lifted by two EDF64 fans (electric ducted fan for those not in the know) . the 64 being the diameter in mm. Propulsion is by 4 Graupner speed280 race motors and 3 bladed 85mm props. It weighs about 1.6Kg, without batteries or controller. The skirt is 45mm foam pipe lagging and looks the business. I tried it on an "instant" pool in the garden. it floated, even with two 6v 4.5Ahr SLA batteries aboard in only about 1" of water and positivly leapt into the air (you know what I mean) when power was applied to the EDf`s. It picks up speed nicely across the kitchen floor and I cant wait to try it tethered with string on the pond to see just how well it does go. The props are a bit small size wize compared to the overall dimensions which means larger props and will have to mean larger motors, I am looking for about 4.5" 4-blade props, an extinct animal according to my surfing. raupner do some wonderful 6" 4 bladers, but this would mean making the craft EVEN BIGGER and would mean another prototype. I do not want to make a smaller craft, size is everything in the WOW! stakes on our pond. Current draw with the set up as is , is 13A, however as it will carry 2 batteries then I will have 9A capacity for a reasonable run time.    Ashley
                                                #15968
                                                Len Ochiltree
                                                  @lenochiltree67043
                                                  Cor! that looks interesting Ashley, any chance of some photos.
                                                  Cold you make some props rather like Bobs SS GT Britain or whatever it is called.
                                                  Len
                                                  #15986
                                                    Len. The trouble with making aircraft props is keeping them in one peice, guaranteed…as if a blade comes off at full revs (and we are talking 16,000 rpm+ for these little monsters) near the pond side………   I did see a 4-blade prop made my simply putting two 2-bladers on the same shaft and from any angle other than dead sideways on it looked ok. I am taking the monster to the weedy pond today just to see how it copes with a bit of surface muck, and how fast it goes (on a tether) . I am likely to have to use a couple of speed 400`s at the rear, which will probably give me sufficient speed on their own, and perhaps a couple of slightly lower power , but same can-size, at the front….370`s or something, to keep the current consumption down.   Ashley     pics today if i can manage to post them.
                                                    #15994
                                                      http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2861/DSCF0512.JPG
                                                      http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2861/DSCF0513.JPG
                                                      http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2861/DSCF0522.JPG
                                                      http://www.modelboats.co.uk/wp-content/uploads/sites/5/images/member_albums/2861/DSCF0524.JPG
                                                      Well here it is, oddly enough a few issues shown up on the pond.
                                                      battery location is critical, weight distribution is everything on hovercraft. The centre tray is too big and possibly stopping air flow under the craft. At “speed”, air is seen to be coming out under the front of the skirt but not the back. The skirt bouyancy is ok for one battery but not two, that is, under power its ok but at rest the skirt is almost covered. You can get larger sizes of foam lagging and I may do so. I have some 110mm props that will fit on the speed 280`s and the motors seem happy driving them, so I think that is what i may use after all,possibly, may be. The trouble with that will be all the props will be rotating the same way, and this may have much more effect on a hover than a multiprop boat. I discovered my 90mm three bladers are in fact handed. I am fiddling with ducting to push more air at the back and allow less to the front. whew! and now my hot glue gun has blown up. Ho hum. Ashley
