How do they do it?
How do they do it?
Home › Forums › Soapbox › How do they do it?
  • #35137
      Hello chaps
      Driving along the motorway, looking at the light stanchions, I have often wondered over the years…….How do they set them so precisely?
      It must be very difficult, and yet so simple to set them parallel to each other, somehow?
      Don't forget too, that once the concrete sets…….That's yer lot!
      Just curious………Bob
      #7943
          Hello Bob
          The holding down bolts are positioned in the formwork before the concrete is poured, they are fixed for line and level using a laser theodolite, after the concrete has set the holding down bolts have an individual movement tolerance of +/- 20mm.
          Easy when you know how.
            Thank you Paul
            I knew you would know the answer!
            Can you imagine the load on those close pitched screws!…….In a strong wind!
              Absolutely amazing. I always thought they started by planting a bulb….
                images.jpg Before the concrete goes in.
                Bob the pull on an M24 bolt is approx 670N
                Colin they plant a tube not a bulb
                Edited By The Fat Controller on 03/07/2012 15:43:42
                #35147
                  Thank you, Paul
                  I'm surprised the screw load is so low……..670 N is only about 175 lb
                  I'm still amazed how parallel they are aligned……In all directions too!
                    Hello Curly
                    The bolts are high tensile steel with very coarse threads and once cast in concrete the only thing they have to do is hold things in position.
                    However the pull load that I quoted is based upon a structural steel frame and not a single lighting pole so there would be extra calculations based upon wind load and potential horizontal impact damage.
                    Alignment using a laser theodolite is fairly easy as you just follow the red dot (setting up the machine though can be a nightmare)
                    Edited By The Fat Controller on 03/07/2012 19:02:39
                    #35177
                    Andy Hustler
                      @andyhustler32076
                      Paul i sit back in amazement , it's nice to now how every day things are made . My father was a marine engineer then after he left the navy he went into civil enginering doing everything from wraping pipes in bitumen to laying sewer discharge pipes in brazil . His father and uncle laid the floor ,in barry island pleasure p[ark , for the dodgems and he always said the island would sink into the waves before the flor fell apart as it was made out of boiler plate .Building model boats teaches people woodworking skills , Basic electronics and in a way some mathematics .
                      My next point ,of sorts !! , my brother belongs to a model enginering club in newport and they have a model boat pond which is not complete as theyt seem to concentrate on steam trains , they are really amazing models but not too hot on the marine side which is a great pity as there is only one place in newport to sail your boats and that tredegar house lake which can be busy with boaters and fishermen . Well thats my moan and groan over with !!!
                      Andy
                      #35179
                        Andy
                        Is your brothers club an informal arrangement or is it a company or charity?
                        If so they could apply for a lottery grant to complete the lake.
