How do I do that?
How do I do that?
Home Forums Soapbox How do I do that?
  • #10171
    Anthony Rumsey
      @anthonyrumsey39979
      how do you upload pictures onto here
      #10172
      Vinnie Branigan
        @vinniebranigan92297
        Anthony, click on the gallery tab above, and then follow the prompts. It’s a bit long-winded but self-explanatory.
        Vinnie
        #10409
        Anthony Rumsey
          @anthonyrumsey39979
          tried it but my pictures are to big cant find a way to reduce the size
          #10413
          Vinnie Branigan
            Anthony, you have to use photo-manipulation software to reduce the size of them I’m afraid.
            Vinnie
            #10416
            Carsten Paulsen
              @carstenpaulsen54581
              I use a program called IrfanView it’s a free download.
              Image -> Resize it’s simple
              Br
              Carsten
              #11005
              JC Uknz 1
                @jcuknz1
                 EDIT …. Sorry I didn’t read who was sending which message and I thought Tony was using Irfanview
                Irfanview will do the job for you perfectly well.  http://www.irfanview.com They like a 10Euro donation if you feel inclined.
                IMAGE > RESIZE/RESAMPLE
                On right of menu I suggest you click on 640×480 as a useful size for a webpage/emails and use the rest of the default settings  ….. click on OK.  This gives you a nice small file for quick downloading, particularly if you are on dial-up like me
                As a check you could save the result with a slightly difference name **and examin the file size on Window Explorer.  My original file was 4.28Mb and Irfanview reduced it to 21Kb which is a nice small size for viewing on the web.  I would normally be using another editing programme for this job which gives me control of the degree of compression I am introducing to reduce the file size after having resized.     The latest version of Irfanview may also do this but I have not ungraded my version for a couple of years or so.
                **this is MOST important becuase if you use the same file name as you started with any saving will kill off your quality camera file and replace it with the tiny web-file.
                #7799
                Anthony Rumsey
                  @anthonyrumsey39979
                Home Forums Soapbox Topics
