Hornet II
Hornet II
Home › Forums › Scratch build › Hornet II
  • #78506
    Martin Field 1
      @martinfield1
      Hi, I have just received some new aluminium solder that I tried out today and it worked superbly well instantly. No brush, no flux, no risk of melting the object as the solder melts at 300 degrees.
      I got it from ebay in 2 days.
      This makes Hornet II's rear deck corners perfectly easy to do.
      I would put a picture on, but Gawd knows how.
      Martin
      #7136
      Martin Field 1
        @martinfield1
        Aluminium solder that works
        #78507
        Kev.W
          @kev-w
          So what is this solder called (trade name) or the sellers name, looks like another good item to keep in the boatyard
          #78508
          Martin Field 1
            @martinfield1
            It's called Alubuild 300 and it came from a company called Able Mabel Crafts!!
            Super stuff.
            Martin
            #78513
            Boiler Bri
              @boilerbri
              I used to do work for Denso Marston who make radiators for wagons and genorators etc. They are all aluminium construction and the joints are all soldered – fused. They coat them in a flux and when heated up the joints all fuse. It was all beyond me but the flux is the special part of the processs. Maybe your product is a derirative of the flux?
              Bri
              #78514
              Martin Field 1
                @martinfield1
                This has the ability, built in, to ignore/disperse the oxide. This is just a stick of aluminium that melts at 300 degrees C.
                Martin
