HMS Kite
HMS Kite
Home › Forums › Scratch build › HMS Kite
  • #14093
    Robert Vassilio
      @robertvassilio11187
      Just finishing up Paul Freshney’s M15 monitor and am looking for a new project.  Was looking at the German gunboat Wespe but cannot find a good set of model plans or a hull.  Then I came across Paul’s Kite plans and became interested.  Does anybody know which month mags had the build articles?
      Thank You
      Robert V
      #14158
      Sailor Bob
        @sailorbob
         Hi Robert:
         Paul Freshey’s article on HMS Kite started in the April ’01 issue of Model Boats and went through until the July ’01 issue.
        Hope this helps,
         Bob W.
        #14159
        Robert Vassilio
          Yes, it most certainly does.
          Thank you
          Robert V
          #14164
          Sailor Bob
            @sailorbob
            Hi again, Robert:
             If you have trouble obtaining the articles of the Kite I have them in my files and would be happy to copy them for you.
            Good luck,
            Bob W.
            #15314
            Bryan Stichbury
              @bryanstichbury74951
              Hi Bob W. Any chance of obtaining the " Kite" articles ? Regards  Bryan
              #15317
              Sailor Bob
                @sailorbob
                Hi Bryan:
                 Yes, can get these to you. I can either print them off in black and white (colour would be about $20 Can) or I can try to download them to a PDF file and put them on a disc.
                Let me know which you would like, I will also need your home address.
                Thanks, Bob
                #15340
                Bryan Stichbury
                  Bob Thankyou for your prompt and courteous reply.However I have since been advised that
                  HMS Kite is not a subject for a raw beginner,so I shall look elsewhere for a suitable project.
                  Once again many thanks  Bryan
                  #15343
                  Sailor Bob
                    @sailorbob
                    Hi Bryan
                     You are right, the Ktie is not a project for beginner but there is a weath of info in the article, mostly ‘how to do’ stuff. If you can borrow the article from someone it will serve you for the future.
                    Good luck with your modelling!
                    Robert Vassilio
