HMS Hood (Hood Hms MM672 – MM672
Home › Forums › Scratch build › HMS Hood (Hood Hms MM672 – MM672
  • #32441
    vic welch
      @vicwelch66071
      Has anyone built this model from the plan and if so what construction details or approaches have been used. I find the plan somewhat lacking in detail and whilst I could make my own judgements I am looking for some experiences and approaches used.
      Additionally the deck seems to be shaped rather tha n flat, is this normal for a boat of this size and type.
      Any advice or tips would be welcome.
      #6749
      vic welch
        @vicwelch66071
        Hull Construction
        #32509
        Francis Macnaughton
          @francismacnaughton39461
          Hi Vic,
          I built this model from the plan in my teens shortly after it came out in the late 60s/early 70s. It is typical of the period in having little detail – there just weren’t the ready made fittings then. As to the decks, mine still has flat decks which is a simplification of the slight camber of the original but the bread-and-butter construction method of the model doesn’t help get camber in anyway.
          Dare I say if you want a really detailed model then you could look at the recently released Hachette partwork with 140 parts at £6 each!
          Francis
