Help with transmitter/radio issues
Home Forums Beginners Help with transmitter/radio issues
  • #35295
    Christopher Gould
      @christophergould43616
      Was testing transmitter yesterday on twin prop Trent Class Lifeboat. Rudder control fine but found that with props that one was running at diff speed to other and sometimes one running but not the other?
      Also, when I turned transmitter off, engine motors kept running until I switched them off using on/off switch. When I switched them back on and tried transmitter again, nothing, and couldn't get the motors turning at all?
      Any help and advice on what to look for/do gratefully received. Thanks in anticipation.
      #2158
      Christopher Gould
        1 channel not working properly
        #35303
        Telstar
          @telstar
          Hi Christopher In order to make an educated guess as to the problem, more info is needed:
          what Tx /Rx system are you using (2.4 G equipment differs from 27 or 45 M)
          What arrangement are you using, Individual motor controle or both together, one speed control or two
          Brushed or brushless motors
          All these things can have a bearing on the problem.. Also in some cases manufacture and type/model of equipment (some speed controls are self setting, others need setting up before use) can matter
          With more info I'm sure there are readers that can offer some suggestions
          Cheers tom
          Edited By Telstar on 17/07/2012 17:01:04
          #35315
          shipwright
            @shipwright
            Hello Christopher,
            Probably worth your while to look at this thread (12th April 2012) :
            " Making twin motors work with 2esc on separate rx channels " in " R/C & Accessories "
            The problem could be almost anything so as Telstar said we need more detail.
