Foamboard/Plasticard
Home › Forums › Scratch build › Foamboard/Plasticard
  • #11152
    Duncan Cameron
      @duncancameron29526
      Hi all,
      I am cosidering costructing my superstructere on my tug of "foamboard (3mm) and covering it  with 1mm plasticard.Has anyone used this method and if so what is the best way of glueing the one to the other? Any hints/tips would be welcome.
      #11178
      Len Ochiltree
        @lenochiltree67043
        I only use 1.5mm Styrene for my superstructures and for the hulls when possible,i have never used foamboard,see my gallery for Styrene models.
        Len
        #11238
        The Reverand
          @thereverand
          Why foamboard Duncan?
          #11244
          Duncan Cameron
            @duncancameron29526
            Hi Dave,
            I thought of using it because it is easy to work with.Then i thought would it weather ok and then considered covering it to make it weather proof. I am giving thought to Len’s viewof using 1.5styrene. Your views would be most welcome.
            Hi Len,
            very impressed with your moddeling skills,your models are first rate.Please see my comments to Dave above.
            #11260
            The Reverand
              @thereverand
              I see what you mean about easy to work with Duncan,i was just wondering how you would cover it.
              1.5 styrene sounds a good option,and looking at Len’s models it definitely works just fine.
              Excellent Len.
              #11265
              Duncan Cameron
                @duncancameron29526
                I was thinking of covering it with the thinnest  styrenr possible. Any views on that : i would of course to get a suitable glue. I am giving serious thought to  using LENS method however.What material are you using?
                #11276
                Len Ochiltree
                  @lenochiltree67043
                  Instead of using the Styrene Solvent that you buy from model shops,go to a Plumbers Merchants and ask for ABS Soil pipe Cleaner, Not the Solvent glue! it does the same job at half the price.
                    Len ( ex Plumber)
                  #11280
                  Duncan Cameron
                    @duncancameron29526
                    Thanks Len i will keep that in mind  if i go ahead using the foamboard.
                    #11284
                    Len Ochiltree
                      @lenochiltree67043
                      Hi Duncan,
                      I am not to sure about using it on foamboard,is it like polystyrene?.
                      I would dump the f/board.
                      Len
                      #11296
                      Duncan Cameron
                        @duncancameron29526
                        Agreed
                        #6410
                        Duncan Cameron
                          @duncancameron29526
