Displacement weight
Displacement weight
Home Forums Beginners Displacement weight
  • #47140
    Alan Coleman
      @alancoleman49879
      Hi all, I have recently purchased my first model to build and (not unusual i guess) have question.
      The model has a displacement weight of 20lbs. Does that mean I have to put it to that weight for her to sit in the water properly?
      #2372
      Alan Coleman
        @alancoleman49879
        #47142
          That's exactly the point that Archimedes got so excited about in his bath. The weight of water displaced is equal to the weight of the model, so if you want it to 'sit' right then it will have to displace 20lbs of water. Don't forget that the model itself will already weigh something, then there's the batteries to add (frequently the sealed lead-acid type) etc, so you may end up not having to add much extra "deadweight" ballast at all. If the model is too heavy for you to launch it just by leaning over from the bank and manually putting it into the water you could make a launching cradle to help you.
          Alan Coleman
            @alancoleman49879
            Many thanks Dave, I thought that might be the case, and now I know.
