Complete Newbie
Complete Newbie
Home Forums Beginners Complete Newbie
  • #62428
    Terry Mackenzie
      @terrymackenzie27215
      Hi all,
      I'am very keen to try a bit of model boat building, but dont know where to start or basic tools required, what I want to build is model fishing vessels for display only, I live on the isle of lewis where there is few good builders with very nice peices, wanting to try myself, does it have to be build from accurate plans to start with? whats best wood for models ect, I have a good boat knowledge as i am an ex fisherman, any advice would be most appreciated thanks in advance
      #2540
      Terry Mackenzie
        #62432
          Terry,
          Why not start with a kit? There are quite a few static display kits for beginners and Cornwall Model Boats have section for static display model ship kits. The request for a beginners static fishing boat does narrow the search down but there are kits to be found.
          I hate making recommendations (in case things don't turn out right), but looking at Hobbies in their Model Boats static display wooden ship models, there are a couple of beginners fishing boats. The first is by Mantua, the Amalfi and the second is by Occre, the Palamos.
          Research on building is of course important and this item on the Build Features section of this site is worth reading. It is the build of a static display beginners kit, HM cutter Sherbourne,
            As far as tools are concerned, there was an excellent article on putting together a basic tool kit in the 2015 Special Issue of Model Boats magazine. Back copies can be ordered here:
            sammyk
              @sammyk
              Hi Terry, a kit is a great way to start and if you hit a snag ask on the forum its a fantastic source of information ,best of luck with your new build. regards sammyk
              #62440
                Hello Terry
                Welcome to the forum.
                If you do opt for a kit have a good look at the reviews before you buy as some kits are complete rubbish.
                As for tools these will obviously depend upon the model that you eventually choose to build as models come in a wide selection of materials ranging from plastic and glassfibre to balsa / plywood and hardwoods. When you have decided upon your choice of model then we will be able to point you in the right direction for the best tools.
                  Terry. I might suggest getting a simple plan, from Myhobbystore (for instance) and having a go at this first. You don't even have to finish it, but it will get you grounded regarding the skills needed and the necessary tools that will be required and a feel for the materials you will be using.
                  THEN you can make a more informed guess as to the sort of kit you would like to attempt for your masterpiece (assuming you go in the kit direction) or you may get a taste for plans only and cutting all the necessary bits out by hand/machine..
                  Amy jane September
                    @amyjaneseptember49770
                    Hi Terry
                    A warm welcome to the forum from me!
                    Aj
                    #62472
                    Terry Mackenzie
                      Thanks for getting back to me folks, very much appreciated, prob will go for one of the above links, i also have very good local builder doing a model of the vessel i work on hes doin the hull for me but in stages for me to see and i will try topside myself with his help, thanks again i will update my progress
