Just out of interest I thought I would do some runs in the test tank (bath) today to get an idea of how much current my motors were using. Each run was done with freshly charged 2 cell Lipo (about 8.4v).
Graupner Speed 600 ECO on 2 blade brass 30mm prop, looks fairly aggressive, flat out 11 amps! The best I ever seen it do on the 6 cell Nicads was 8 amps. looks like the extra ooomph of the Lipo has pushed it up a bit. So getting on for 90 watts consumption, quoted 72% efficient, about 65 watts at the shaft.
Tornado Thumper 2836/08 1120kv on 3 blade plastic 40mm prop, standard cheap plastic not very aggressive, flat out 7.5 amps. This motor is rated at 20 amps on 4 cell Lipo, so halving the number of cells reduces the consumption by more than half. So if we say the motor 85% efficient, about 52 watts at the shaft.
Last check was with the prop of the first test, 30mm brass, on the brushless Tornado 2836/08. This should give a like for like same prop load etc. This time the current draw was up to 8.5 amps. Maths done and about 60 watts at the shaft.
So the brushed Speed 600 ECO has about the same output as the brushless Tornado 2836/08 on a like for like propeller using 2S Lipo. The difference is the brushless is about 25% of the size, and running at less than 50% of it's max output (so running a lot cooler and last longer).
None of this is really relevant on a slower model, but if you are building a faster style design then it might be of use. All the test showed 4 amps on what seemed like half power and more normal speeds rather than flat out.
