Boiler certificate
Boiler certificate
Home › Forums › Steam powered models › Boiler certificate
  • #16773
    william macleod
      @williammacleod30860
      Hi,
        Just purchased a steamboat with a Cheddar pintail boiler. It came with a boiler certificate.
       how long is the certificate valid for ?
      Thanks.
      Bill
      #16774
      Ian Kennedy
        @iankennedy31889
        Hi Bill,
        From my dealings with steam boats i can tell you that the boiler should really be tested annually, this is a hydraulic test on the boiler taken to 1.5 times its working pressure to check for structural integrity.
        there should be no visible leaks and distortion of the boiler and it has to hold a constant pressure for a set amount of time, if the pressure drops then the boiler will fail the test.
        You can contact any local model engineering club who will i’m sure test your boiler and issue you with a new certificate.
        Hope this hasn’t scared you but it is important for your own safety, as these things can go wrong if not looked after correctly.
        #16786
        Phil Abbott
          @philabbott79958
          Boiler certificates are usually valid for 2 years from the date of test (MPBA guidelines) and then subject as Ian says to a hydraulic test
          #7267
          william macleod
            #18316
            Geoff Yarham
              @geoffyarham31662
              BILL, Boilers do need a certifacate, but the test time depends on the size,pressure and materials. Try a model engineering site for all the rules.  Geoff Yarham.
              My steam powered paddler.
              #18398
              hammer
                @hammer
                Bill, Bar-Litres. This is the total volume of the boiler (in litres) multiplied by working pressure (in bars. 1bar = 14.5lbpsi) This should be on the test certificate. Boilers below 1.5 bar-litres only have to be tested once. So if you have the original Chedder cert; the boiler is more than likely to be under 1.5 B-L.  But I would say always test a second hand boiler as you dont know how it has been used.  Geoff
              Home › Forums › Steam powered models › Topics
