boiler bushing
boiler bushing
Home › Forums › Steam powered models › boiler bushing
  • #83931
    charlie f
      @charlief
      I plan to screw a stainless steel fitting in to a boiler bushing
      will this mixture cause any problems
      #7365
      charlie f
        @charlief
        #83935
          Hi Charlie
          What material are the bushes in your boiler made from ?
          Is it a commercially produced boiler ? Does the maker have a view ?
          Sorry for all the Questions but it help you getting an answer 😀
          charlie f
            @charlief
            Hi Ray it is a bushing from Clevedon steam
            #83937
            Eddie Lancaster
              @eddielancaster
              Hi.Charlie, personally I wouldn't use stainless on the steam side of a boiler, at higher pressures and temperature it is too unpredictable. Stainless is not allowed on full size engines or larger scale models either as fixings or steam fittings.
              These days you need a good quality gun metal, a zinc free brass.
              Hope this helps.
              Eddie.
              #83938
                Hi Charlie,
                I would agree with Eddie as he is a very experienced steam man, my only suggestion would be the use of PTFE tape round your stainless fittings thread and create a barrier and seal ??
              Home › Forums › Steam powered models › Topics
