Forums
Help
Register
Log in
Home › Forums › Scratch build › Blocks and pulleys
Where can I buy blocks and pulleys suitable for a Modern Fishing Vessel at a scale of 1:20?
Cheers
Hi
Squires
100 London Rd.
Bognor Regis
PO21 1DD
tel. 01243 842424
do min brass pulleys 4mm dia, 6mm dia their catalogue is a treasure trove
Hi Peter not sure what yr looking for , this sight may help
http://www.rbmodel.com/rbmodel.pdf
Think you can go direct to Germany or http://www.redbank-models.co.uk/ are agents.
Hi, I usually make mine out of styrene, but if you dont want to make them then you could try Mastman, I think he has a web site. they will be at 1/24th as they are for Thames Barges,
Good luck
Thanks to you all, I shall try them all and publish some pictures when complete.
Will Mason 1
Philip Oxley
Queequeg Quint
Boiler Bri
