amphicar
amphicar
Home › Forums › Scratch build › amphicar
  • #16354
    the converter
      @theconverter
      hi can any one help i’m looking for full or not to scale plans for an amphicar for my youngest looking to get into hobby and wants to build one of these .
      many thanks
      #16356
        not sure but I think the old MAP plans service used to do a set for this car.
        can be found in Model Boats mag,
        failing that the X Plans set.also advertised in MB
        #16369
        the converter
          @theconverter
          hi neil thanks for info
          #16422
          Kiwimodeller
            @kiwimodeller
            There was definitely an article in one of the mags in the early 90’s on how the writer had built one. Will see if I can find it at the weekend when I go to my storage shed. Cheers, Ian.
            #16426
              the converter
                @theconverter
                thanks for info paul looking at the details on the sites i should be able to sort something out for my lad.
                thanks ian would be gratefull of details of which mag the article was in then can order copy .
                #16544
                Kiwimodeller
                  @kiwimodeller
                  The article was in Model Boats January 2005. Although not a plan feature there are some basic drawings you might be able to scale and it is a very comprehensive article several pages long with many photos of building the model with botth wheel and prop drive. Hope this helps, regards, Ian.
                  #16554
                  the converter
                    @theconverter
                    hi ian many thanks will look out for a copy
                    #16581
                      A seller (shop) on ebay called ‘Georges Attic Gifts’ occaisionally has an article for sale. Not currently in the shop, but worth checking from time to time.
                      Tony.
                      #16597
                      the converter
                        @theconverter
                        hi tony thanks for info will check it out
                        #16624
                        Kiwimodeller
                          @kiwimodeller
                          Canyou not order back issues through this website? You always used to be able to.
                          #16631
                          the converter
                            @theconverter
                            have tried hobbystore with no luck even tried ebay no luck there either seems to be one of those mags not easy to find or get hold of
                            #16645
                            Kiwimodeller
                              @kiwimodeller
                              Have sent you a P M re this.
                              #16953
                              Grumpy
                                @grumpy
                                Hi there,
                                Don’t know if it will be of any help but Rick Eyrich did a very interesting article on the history of this vehicle in the September 2002 issue of Marine Modelling.  If it is of any use I can let you have a copy of it
                                Grumpy
                                #6504
                                the converter
                                  @theconverter
                                  plans wanted
                                  #18367
                                  Robert Hinton
                                    @roberthinton55347
                                    Hi Keepontrukin,
                                    Sorry I have come in a bit late to this correspondence but I have only just found this site and joined in.  I built the model and wrote the January 2005 article referred to earlier and I still have the model which gets regular public outings.  I have just tried it in the snow but the grip was poor!  I would be happy to help you with your project.  I can send you a copy of the article if you cannot get hold of a back copy, including the nice article in MMI that inspired me to start the model.
                                    The easiest way to make your own plans is to measure and photograph the one kept on occasional public display in the Sxcience Museu’s Large Exhibits’ collection at Wroughton in Wiltshire.  They were very helpful to me.  Feel free to contact me on [email protected] , I would be happy to lend you my sketch plans for you to copy if that would help but I did modify things a bit as I went along!
                                    One word of warning, I have been model making for over 40 years and this is quite an ambitious model, not recommended for beginners.  Getting land drives and water drives with switching over and wheel steering and prop steering is all possible but a bit tricky – especially as space is a bit limited if you want to keep the seating and footwell areas free.
                                    mick
                                      @mick
                                      hiya keepon trucking
                                      i  have some plans if an amphicar i got off ebay  you make the running gear up from mecharno bits and bobs ply body  the steering and the mechanical speed controller
                                      work on the same servo   i looks like a 540 buggy motor and scratch build the rest
                                      if your interested let me know i will get some printed up ok hope this helps mick
