Aerokits 36″ RAF Crash Tender deck fittings sought.
Home › Forums › Scratch build › Aerokits 36″ RAF Crash Tender deck fittings sought.
  • #6799
    Rick Devonshire
      @rickdevonshire
      Does anyone cast these in resin?
      #34258
      Rick Devonshire
        @rickdevonshire
        I am nearing the end of building a model of the 36 inch version of the KielKraft RAF Crash Tender, from the original plans, and need the deck fittings for the craft. I have managed to keep the weight down to 3.5kg by means of careful wood selection. She is powered by two Graupner Speed 600 ECO motors which produced a lively turn of speed at her first trials on the water the other day.
        I have obtained a set of white metal castings of the deck fittings but found the weight of these are 1 kg and am concerned that such an addition, increasing the weight by about a third, would have a detrimental effect on her performance.
        Does anyone know if resin castings of these fitting can be obtained from anywhere?
        #34260
          yes, Caldercraft-Jotika ltd
          #34262
          Rick Devonshire
            @rickdevonshire
            Many thanks Neil.
