1913 Gaff Rigged French Pilot Cutter
Home Forums Scratch build 1913 Gaff Rigged French Pilot Cutter
  • #12619
    Tony Bell 2
      @tonybell2
      I have always wanted to build the "Jolie Brise" the 1913 French Pilot cutter , It is still sailing today so I have access to many pictures on their website. The plans are also French and have many errors especially the frames. It is nearly completed, Tank testing showed up a major fault. It’s too low in the water. Goto http://www.joliebrisemodels.co.uk  Any ideas for my second version welcomed.
      One problem I want to solve is where should the ballast be placed. Directly under the Center of Gravity or spread out along the keel. What difference does it make.
      Tony
      #6436
      Tony Bell 2
        @tonybell2
