The bridge area coming along nicely showing 2 of 4 20mm AA gun tubs
Looking into the tank deck,this section is a lift of piece.
side view of the stern
And the bow
Ramp to the upper deck which can carry more tanks/vehicles and 2 of the 3 forward gun tubs not glued in yet as these will be raised which will probably house 2 single 40mm AA and 1 Dual 40mm AA.
And the ramp closed[/quote]
"Hi guys finally got back to this this week and thought I would post a few pictures
Starboard side LCVP mounted on its davit needs quite a bit of detail yet so it looks a little rough
Looking towards the bridge side view of the davits
[quote="Treadhead"]Hello gents I've had one of those periods you get where I really can't pick up a paint brush let alone do any modelling thankfully I'm back in the swing of it so I thought its time for an up date.
Pointy end of the ship with three of the gun tubs one of which is a 40mm quad mount the other two are 40mm twin mounts.
midship showing some of the Carly floats being added the uprights which their attached to are a bit improvisation as these I think were attached to the ships railing which I'm not going to add as they'll be the first thing to break.
Bow doors which open and close wide enough for an Airfix Buffalo.
I've actually had to learn a few technics to get this far with it the gun tubs in particular were a bit of a night mare to get right as the pile of discarded tubs would show, as you can see though its nearly complete just a case now of filling in the detail which I'm hoping I can do over the next week.[/quote]
[quote="Treadhead"]Well its finally finished though I have seen a few bits that need more attention with the paint brush.
I've really enjoyed putting this together but there were times I doubted it was going to be completed.
Again like the LCT I could have packed a lot of detail onto the decks such as ammo lockers ramp hoist and electric anchor motor but again had to stop myself this is a wargame piece not a shelf queen and I figure
A good set of crew figures would help bring the decks alive a bit.
Most of the Allied landing craft fleet were pretty low on the maintenance list so looked pretty battered not entirely sure I've done that.
a pretty packed top deck.
Insides of the gun tubs look a little to clean so need rusting up a bit.
The bridge area and LCVP's straps holding the boats need a bit of a wash.[/quote]
Edited By THOMAS MCCAFFERTY on 30/01/2015 17:18:15
