Water outlet position
Home › Forums › Beginners › Water outlet position
  • #60818
    Wayne Clarke
      @wayneclarke38583
      Is it ok to have the water outlet coming out through the transom rather than one side
      #2511
      Wayne Clarke
        @wayneclarke38583
        #60819
          Hi Wayne. If you are modelling a particular craft the obviously the water outlet has to be where it is, but other than it doesnt make any difference. You do not want it in a position so that the oncoming rush of water impedes the flow of exiting water, but anywhere really. It is handy to be able to see the water coming out if its a fast craft as a check to see all is ok..
          Wayne Clarke
            @wayneclarke38583
            Thank you so it will be a rear exit
