Servo Travel
Servo Travel
Home › Forums › R/C & Accessories › Servo Travel
  • #11393
      Hi,
      Can anyone advise or recommend an R/C set which will give adjustable travel on the servo (or winch). I currently have 3 sets, all 27meg, 2 channel, which have fixed travel. I am looking to purchase a new set, 40meg, 2 or 3 channel with the added feature of adjustable travel length for the servo arm. It will control a lever arm servo on a yacht.
      Thanks Tony Hadley.
      #11397
      The Reverand
        @thereverand
        Hi tony
        The futaba 4 channel 4ex 40mhz has adjustable servo travel.
        #11403
          Thanks Dave.
          #11407
          The Reverand
            @thereverand
            Tony what i didn’t mention about this R/C set it also has reversible servo too.
            dave.
            #11410
              Thanks again Dave,
              Following your answers, and researching further, this looks the set for the job. Although not cheap the fuctions are superb. I will be staying with the crystal sets and not using the 2.4 ghz yet.
              So a little ‘retail therapy’ is due.
              Tony
              #11482
              George Papandropoulos 1
                @georgepapandropoulos1
                Hi Tony,
                I am not quite sure I understand your question, yet I will try to answer ( a most illogical action ).
                I have been faced with the problem in rotating a gun by almost 360 deg. something that no ordinary servo can do. So I disassembled the servo used the motor with a proper gearbox and attached the feedback pot with such a reduction gear set to get the ratio of the ordinary servo rotation angle to 360 deg. connected motor and pot to the electronics and the thing worked. One word of advise though. One should be very carefull about the load and gear play to avoid the danger of servo getting into oscillation ( a back and forth move in an effort to zero pot position ).
                I don’t really know if I answered your question but I spent some time bragging, which feeds my ego…
                George
                #4933
