Thanks Ray, Malcolm, I wanted to avoid going straight into detail initially. My question was more or less along the lines of 'what is a sail winch anyway'.
So to go into a bit more detail about this particular project. I'm indebted to Alan Izzard primarily for translating a set of build log photos into some helpful hints.
Probably most efficient if I give a link to Alan's photo bucket site.
https://app.photobucket.com/u/montessa315/a/3cebd09a-843c-4bb6-b71e-2dc37a0faeba
I hope that works as expected.
Alan said he used whatever servos he had to hand, having built a servo carrier over the re-inforced keel, which provides the ~1/2" space for the servos. The photos don't show the part number clearly, but I've tried to avoid just copying what Alan did directly – at least try and get some understanding of his thought process.
You'll see the sail servo has main and jib sheets via a long arm, which is the 'model' I shall follow.
Thanks for your thoughts so far..
Edited By Jeff Adams on 21/01/2021 13:13:46
Edited By Jeff Adams on 21/01/2021 13:30:55
