cooling system
cooling system
Home › Forums › R/C & Accessories › cooling system
  • #14091
    Jake Knight
      @jakeknight71345
      hi guys
      is thare any way to make your own cooling rings for the motors?
      because i want to keep costs down
      #14106
      Charles Oates
        @charlesoates31738
        Hi Jake, I presume you want this for electric motors.
        Get a length of small bore copper tube aroung 2 mm i/d. Heat it to red hot and quench it in cold water. This will make it ductile, or easy to bend. Wrap a few turns around the motor,  and lead the ends to a suitable location for conecting up. that about does it.
        This method has been used for decades and works very well.
         Chas
        #14114
        Jake Knight
          @jakeknight71345
           i though i could do it some way like that
          do you know where i could get the copper pipe from as my local hobbie shop only sales brass
          thanks
          jake
          #14118
            Hi Jake
            Try your local plumbers merchant and ask for 6mm OD microbore pipe this will give you an internal dia of 3mm, but as 6mm is quite rare these days you might have to get 8mm OD which will give you @ 5mm internal dia.
            Follow Chas’s instructions to make it ductile and to make the bending easier and to avoid squashing the pipe walls try packing the pipe with dry sand, this will support the pipe walls whilst you bend it around the tight dia of a motor casing.
            However in this modern age plumbers merchants also have microbore plastic pipe which is heat resistant and easy to bend.
            Good luck
            Jake Knight
              @jakeknight71345
              thanks paul i was worried about the walls bending inwards
              thanks paul
              #14125
                Hi Jake
                No problem just remember to seal the ends of the pipe up before you start bending it.
                Cheers
                Jake Knight
                  @jakeknight71345
                  why do you have to seal the ends up
                  is it to not let the sand out?
                  thanks again
                  jake
                  #14131
                    Sorry Jake
                    I did not explain myself very well, the process of sand filled copper pipe bending requires that one end of the pipe be sealed or stopped up (with a good bung) then you fill the pipe with sand and ram it in tight and then you bung up the other end so that the sand can’t come out whilst bending.
                    Once you have finished all the bending then you remove both bungs and get the sand out.
                    Hope that this is clearer. (I am a dufus sometimes)
                    Manxman
                      @manxman
                      B&Q sell 6-8-10mm micro bore copper pipe for heating systems, check their web site http://www.diy.com
                      I have to admit though I’ve never seen cooling coils so thick,  I’ve only seen them in 3mm copper and 4/5mm aluminium – for the smaller pipe try your local car scrap yard.  Oil pressure gauges always used them on the older cars, just need a Little cleaning with hot water and washing up soap !
                      Cheers – Ken
                      ps – just checked B&Qs site and they are not listing 6mm – though they do sell it in the bigger stores, you may need to try a normal plumbers store.
                      #14142
                        These cooling coils …ready made ….are availabell in most model shops.
                        As a matter of fact ……..But….I`ve never fitted a cooling tube to any of my motorised models?
                        Bob the Hothead
                        #14143
                        Charles Oates
                          @charlesoates31738
                          you could go to a good motor factors and get some copper break pipe. not expensive and it worked for me.
                          chas
                          #14145
                          Jake Knight
                            @jakeknight71345
                            well thanks guy
                            i got hold of the copper the other day any they have came out well
                            thanks again
                            jake
                            #4966
                            Jake Knight
                              @jakeknight71345
