Vic Smeed’s Silver Mist
  • This topic has 822 replies, 4 voices, and was last updated 1 day, 3 hours ago by Colin Bishop.
Viewing 25 posts - 251 through 275 (of 823 total)
  • #65627
      Captain Bob
      As we have discussed on many occasions Kevin is an avid follower of your projects and presumably learning a great deal from your 'warts and all' approach but there are times when you unconsciously let your zeal run away with you and you forget to explain some aspects of your model building philosophises.
      For example your excellent advice regarding having the rudder square to the waterline didn't go on to explain why you, as an expert builder consider this to be important.
      The other expert modellers who are following this thread might occasionally drop in to help with your explanations and then withdraw back into the shadows so as not to distract from your very individual style.
        Thank you, Paul, for your post and advice
        I don't really think an explanation is justified?
        The rudder should be square to the water line, purely for it's aesthetic quality only
        One degree out in any direction, to an engineer stands out a mile…….Like a cock eyed picture on the wall!
          In this case the explanation simply helps Kevin who might be confused as sometimes a boat / ship might not have a rudder that is square to the waterline.
          DMs comment about the Moonbeam's rudder is a case in point where a brief explanation might be a huge help to Kevin in helping him understand.
            So it isn't really an "essential requirement" at all then? I'm rather relieved because I've spent ten minutes studying the photographs of Bob's model and I can't see any usable reference line on the hull save the bottom edge of the skeg. I'm off now to pick some nits elsewhere – promise!
              Kevin
              Perhaps I`ve not explained myself clearly enough for the discerning nit picker?
              The water line is represented by a plank that rests on the keel at the stern, and packed up, 1.55" at the bows
              There is a vertical hole in the plank, with a brass bush and it is used as a guide to drill a vertical hole, at right angles to the water line, through the hull and through the rudder deck
                Rudders can be fitted at all sorts of angles, it depends on the boat. Yachts frequently have single rudders which hang at an angle, sloping forward towards the keel. Modern yachts with twin rudders often have them splayed out to the sides at opposite angles so that when the boat is heeling one rudder is somewhere near the vertical and is more efficient.
                Silver Mist has a conventional arrangement where the rudder is essentially vertical and in line with the keel.
                Some vessels don't have rudders at all but let's not confuse Kevin….
                  Work in progress
                  Does my B** look big in this?
                  Checking and adjusting the pointy tail end to be in line with the rudder axis
                    Chaps: I am larfing too much to see the pictures properly!!
                    ​Discerning nit-picker …its just toooo much !
                    I know what Bob means…a nice traditional boat like this has to have a vertical rudder. I fully agree.
                    Oddly enough I don't think any on my craft have anything BUT vertical (ish) rudders despite not being traditional, although only the Alvis has NO rudder as this is controlled by differential motor manipulation..and having said that it could do with a rudder to keep going in a straight line.
                    Are you going to use that (presumably GE) propeller Bob? or is it just there for effect?
                      Thank you, Ashley……..Pleased that you enjoyed the post
                      And you spotted the old GE prop too!………It's only there to stop the propshaft falling out
                        Ho! Ho! Ho!…….This could be fun?
                        Going to make use of an old rudder………But the rudder shaft is too short
                        Need to extend it, using a short length of brass tube
                        The shaft needs to be turned down to 3 mm…..In the lathe……..For a nice soldered accurate joint
                        Due to the rudder blade being in the way, we will need to use the three point steady!
                        This is worth a look, Colin………..But be very careful!………..This could be quite dangerous, in the wrong hands!
                        Due to the rudder blade flying about!
                        This is the setup……
                        Rudder shaft in chuck with the end to be turned, loosely held in the drill chuck
                        The steady pads are adjusted to a nice running fit on the rudder shaft………Then the tailstock is moved out of the way
                        Avoid any loose clothing in the area,,,,,Ties especially
                        Be aware of the rudder blade hazard……..Rotate the chuck by hand, to ensure all is ready and safe
                        Switch on and carefully turn the shaft…….Turning a 4mm shaft needs special care, as it could dip and destroy itself
                        Eventually…….Job done
                        Due to problems with Win 10, the post will be released in stages
                          Part 2
                          The rudder shaft is being turned
                          For small diameter jobs…….Use a very sharp tool
                          Note the dangerous rotating blade
                          In the real world, this operation is highly dangerous
                          When I was a turner in the fifties, it was a common practice……..Turning gear shift arms
                          Sadly, I witness some ghastly accidents
                            image.jpegThe post is being fragmented, because I can't locate the stored photos
                            No doubt, all will be clear shortly
                            The final assembly
                              A club member has donated an old looking motor to the project
                              It`s an MFA "Marlin"……..Same size as an MFA 850
                              High Torque Marine motor….12 volts…..5100 rpm…..68 watts
                              Could be a suitable motor from the Good Old Days, that Vic would approve?
                              Many thanks Jimmie
                              Any good?
                                Bob. I think that this is what the 800/850 motors were called (Marlin) before they were called 800/850.
                                At 5100 rpm yours would be an 800 and a suitable choice.
                                  Many thanks, Ashley
                                  I thought it would be suitabell…….The number of times, I've come across it in the junk drawer, wondering whether to fling it or not!
                                  It will give the model……Character!
                                  At the moment, progress is slowing down, I'm in need of a 2mm sheet for the deck…..and we've run out of model shops!
                                  Nearest shops are 40 miles and 60 miles away!
                                  Hmmmmmmm………I've got a sheet of Hardboard here?
                                  Ah well……Back to the hull
                                    You could order some from SLEC Bob **LINK** The postage is unlikely to be more than driving costs to the model shops.
                                      Thank you, Colin
                                      We will be going past either of the two model shops within the next week……..On the way to Wales
                                      I need a few port holes anyway
                                      I know Slec is a good source, I've used them a few times
                                      Have you seen the turning demo with the three point steady, a few pages back?
                                      Useful to be aware
                                        Hi Bob/All
                                        SLEC are doing cheap Birch ply with external laminations across ie 60" x 12" x 1/8" cost £1.96 !! Great for bulkheads etc. just had 5 sheets delivered
                                          Ray
                                          Thanks for letting us know about this great deal.yes
                                          All the best
                                            Many thanks Ray
                                            I`ve had a look at the Slec website and quite surprised at the low prices
                                            I`ll get some on order……Right away
                                            Hi Paul
                                              Hello Captain
                                              Fancy us two missing such a good deal, it just goes to show that you have to keep your eyes open.
                                              Big thanks to Ray
                                              Well done on the lathe master class, there aren't many who could turn such a narrow section without it whipping all over the workshop.
                                              I'm looking forward to seeing the superstructure on the Silver Mist so get yur finger out.
                                                All in good time, Doc!
                                                Another set up
                                                Set at water level………With the keel sloping up at 1.6" and the rudder vertical
                                                It has the look of a trawler and takes some getting used to
                                                The port holes should improve matters………Tomorrow
                                                  Work in progress……Progress at last!
                                                  Painted the inside of the hull, prior to fitting the lid
                                                  Quite a lot of the inside is quite inaccessible, once the top is glued in place
                                                  Did have a few more pix to post, but the Win10 Gremlins are still active!
                                                  Edited By Bob Abell on 01/06/2016 18:38:38
                                                  #65801
                                                    Hi Chaps
                                                    Filled out all the paperwork for 12 sheets of assorted ply from Slec, but fell at the last hurdle!
                                                    The system couldn`t cope for some strange reason……..So it was Plan B after all
                                                    Cheap type 3mm ply offcut from the local shop……….With the grain going the wrong way
                                                    It was 3mm with a 2.5mm core and 0.25mm skins……..But it didn`t like bending, camberwise!
                                                    Soon persuaded it to cooperate though………I cut the skin underneath, with the scalpel, up and down the sheet and it was instantly pliable
                                                    Just look how handy those portholes are!……….Ideal for the lacky band anchorages
                                                    And for good measure……..The water treatment
                                                    I rather like the idea of building this model from salvaged recycled assorted grot, lying about the floor?
                                                    Just decided to use an old MFA BOB`S type board for the Speed Controller now……..Feel sure, Vic would approve?
                                                      How`s this for the Fickle Finger of Fate?
                                                      The controller being recycled is off a previous model…………."Starlet"………..By Vic Smeed himself!
                                                      What could be better?
