Vic Smeed’s Silver Mist
  • This topic has 822 replies, 4 voices, and was last updated 1 day, 8 hours ago by Colin Bishop.
Viewing 25 posts - 226 through 250 (of 823 total)
  • #65541
      Steady on Ray
      You are getting tooo technical for Bob wink keep it simple and liberally scattered with cups of tea.
      Edited By Paul T on 20/05/2016 13:25:30
        Hi Bob
        I think all glass fibre resin is polyester based, I've used West Epoxy resin inside my boats when I have it in stock, its expensive and in the past I've had problems with it not going off fully. I had that problem with outside of my balsa planked Silver Mist, I ended up putting the hull in the airing cupboard for a couple of days which pleased she who must be obeyed a great deal Had I read the instructions it probably said it had to be 15 Deg or above.
        Ian Gardner
          @iangardner62867
          That's looking great Bob- did you need help turning her over!laugh
          I'm really looking forward to seeing her progress. You may remember I changed the cabin window shapes on mine as I found some real life examples done the same way -and it saves finding a way of making those shaped window frames.
          All the best,
          #65545
            Thank you, Paul, Ray and Ian
            As well as making the stand, I`m in the throes of sorting out the actual construction of the cabins
            At the moment the drawing is rather too condensed!
            I think Vic was trying to save paper?
            The curly cabin sides, look nice, but don`t seem to have any support for the curly end bits?
            Perhaps I`m having another Senior Moment?
              No Bob its still the same one that started when you were building Brutus, mine started in 2005!
              #65547
                This will be your next stage, best of luck
                #65548
                  You know what they say, Paul
                  Ignorance is bliss!
                    Something for the weekend Sir?
                    Removed the building spine and made a start on the stand
                    With SloMo in the background as a size comparison…………..Silver Mist is looking a bit OTT?
                    But once large boats get on the water……..They do shrink somewhat!
                    #65591
                      Hey up!………What`s he doing now?………I hear you ask
                      Well chaps, I`ve decided to have one motor drive as Vic decreed……Especially, when I`ve found in the junk box, a vintage MFA type 850 motor, one prop shaft and the rudder off Great Eastern…….And it`s a Becker type too
                      The snag is…….We need a hole up the keel………At this late stage too!
                      A tricky job, but also an engineering challenge!
                      First job, is to saw through the keel, up to the hull…….Easy
                      Next job………..Drill about 8" through the centre of the 8mm keel…….With an 8mm drill!……..Tricky
                      Problem……..Ain`t got an 8mm drill
                      Answer……….Make one!………OK Boss
                      Problem……How do we stop the drill wandering?
                      Answer………Fit metal guides……OK Boss
                      And it worked a treat………….More pix to follow
                      First picture, showing sawn slot through keel
                      2nd picture………8mm home made tube drill……..Drilled down the centre with 6mm drill, and with teeth filed at the cutting end
                      Also shows, steel plates, top and bottom………To stop the drill wandering!…………Clever….eh?
                      Pictures to follow showing inside the hull
                      Your comments are welcome
                      #65592
                        Heath Robinson would be proud wink
                        #65595
                          Thank you, Paul
                          Mr H Robinson believed in the saying……..
                          "Many a true word was spoken in jest"
                          How else could could you have produced an 8mm hole, down an 8 mm thick keel x 8" deep……….Dead on?????
                          Anybody?
                            Kevin would like to see the inside, please?
                            He doesn`t really………I just made that up
                            Bob………Nice?
                            What`s that?……….What`s that screw doing there?
                            We needed another five thou for clearance, so I used an 8mm screw………Running in reverse of course
                            #65605
                              In answer to your question of How else could could you have produced an 8mm hole, down an 8 mm thick keel x 8" deep……….Dead on?????
                              The answer is very easily, just stick to the design and do it before planking.idea
                              By the way have you got shares in Isopon?
                              Edited By Paul T on 23/05/2016 17:57:53
                              #65609
                                The need to drill a keel out, must arise very often, old chap?
                                This is just my method of doing it
                                BTW…….I don`t possess a Crystal Ball
                                  Hello Chief Engineer
                                  For those without crystal balls and who lack your natural ingenuity they could use one of these
                                  Its a mortise tool and they come with square and round chisels.
                                  Edited By Paul T on 24/05/2016 11:29:43
                                  #65613
                                    Hi Paul
                                    For your suggestion to work………You are going to need a Crystal Ball………And a Magic Wand!
                                    Stand by for my next trick………..Drilling a vertical hole on a cockeyed surface.for the rudder tube
                                      While standing up in a hammock, Bob?
                                      #65615
                                        Just you wait and see!
                                          Far from needing a crystal ball or a magic wand the mortise drill works very well and is my 'go to tool' when builders ask for help when they, like you have either changed their minds about the design or simply forgotten to allow for the tube.
                                          Clamping the hull firmly to the work bench and having the drill press set to the correct angle ensures a problem free procedure, in fact it takes 20 minutes to set up the job and 20 seconds to actually drill the hole but I get a perfectly straight and accurately sized hole without the need to invent new tools or stand on my head with a piece of studbar in one hand and a bent screwdriver in the other.
                                          Surprisingly enough people are prepared to pay £30 for this service
                                            Having trouble sorting out the pictures, at the moment, chaps
                                            Windows 10 is not being very cooperative today
                                            In order to drill the hull to take the rudder tube, at the correct angle, I made a drilling jig plank
                                            It rested on the keel at the stern, but needed to be packed up at the front, to allow for the keel slope
                                            Had to make another special drill, using the rudder bush in the plank as a drill guide, to drill down through the hull and through the rudder deck
                                            Can`t guarantee the accuracy of the hole sideways, but it can be adjusted quite easily, the essential requirement was to get the rudder shaft square to the water line……..Fingers crossed
                                            We`ll soon find out!
                                            #65619
                                              Kevin wants to know why this is considered "essential", particularly as he has been following Banjoman's build of Moonbeam.
                                                Hello Dave
                                                It only is essential, because that's how it is on the drawing
                                                What are you suggesting otherwise?
                                                  I'm suggesting that, while aesthetically it might be desirable to get the rudder shaft square to the waterline, from a practical point of view it's not as absolutely necessary as the word 'essential' implies. Kevin may have noticed that the axis of the rudder hinge on Moonbeam is anything but square to the waterline and wondered about the apparent contradiction – although that's possibly an extreme example. I hope that's cleared it up for him.
                                                  Carry on, skipper.
                                                  Banjoman
                                                    @banjoman
                                                    Bob,
                                                    Heath-Robinson or not, for my part I found your set-ups to solve your drilling problems most ingenious, and they clearly got the jobs done nicely — a fine example of necessesity-and-invention interplay, I'd say!
                                                    /Mattias
                                                    #65624
                                                      A voice in the wilderness!
                                                      Thank you very much, Banjo……….You are very kind
                                                      In many cases, I could have guessed the various little jobs……Or as we sometimes say……."Knife and forked it", but finding a precise little trick or method is great fun to me
                                                      I used to run a thread for similar, tricks of the trade………"Eureke Moments"
                                                      I think, some of your ideas may qualify?
                                                      The Nit Pickers like to have their say, but they mean no harm
