Wood Glue
Wood Glue
Home Forums Beginners Wood Glue
  • #53220
      Hi,
      What is the best type of wood glue nowadays? I've been using the normal Evo-Stick Resin-W which Glynn Guest always uses in his magazine items.
      The plastic bottle is running low and I need to buy new – is there a better alternative today?
      Thank-you,
      Tony.
      #2440
        What is the Best
        #53222
          I always use either aliphatic resin or Deluxe materials Super Phatic which I think are better that the standard Evo Stik glue. The Super Phatic is effectively a 'superglue' for wood (and other materials) and really effective while the aliphatic resin is suitable for larger areas and dries more quickly than Evo Stik with 'quick grab' and is more water resistant..
          Evo Stik is OK but these two glues are a whole lot better to work with.
            Agreed. SuperPhatic is excellent stuff but doesn't go very far before you have to re-invest. DeLuxe Materials also do a conventional Aliphatic Resin glue. I use both in tandem; the normal stuff where quick drying isn't so important. They both sand a lot easier than PVA.
            Edited By Dave Milbourn on 31/10/2014 23:37:30
            #53228
              Thanks for the replies, DeLuxe Materials are always an excellent product and I will order both of these suggested products. Good to hear of the quicker drying properties and easier to sand.
              Thanks again for the prompt replies.
              Tony.
              #53231
                Tony
                Are you old enough to remember the smell of the Fish glue, in the Woodwork Shop at school?
                It was a pot of glue in a pot of boiling water……..It smelt lovely…..As did the smell of Harbutt`s Plasticine?
                Those were the days!
                  Remember the fish glue well in woodwork well, I don't remember Harbutt's Plasticine though.
                  Woodwork – loved it, passed it as a GCE subject.
                  Tony.
                  #53471
                  andrew jolly
                    @andrewjolly45059
                    Posted by Bob Abell on 01/11/2014 08:17:21:
                    Tony
                    bloody hell I remember the smell well bob .brings back good old days
                    #55558
                    Mike Dunn
                      @mikedunn19317
                      pva wood glue cant beat it
                      mike
                      #56273
                      Peter Nurse
                        @peternurse84284
                        Titebond III is a fully waterproof aliphatic glue.
                        It can easily be sanded and does not ball-up like PVA.
                        It has a set-up time of around 30 minutes and is fully hardened after 24 hours.
                        Wipe off any surplus with a wet cloth as it can leave a brown stain.
                        Peter
                        #56286
                        Sm shogun
                          @smshogun38232
                          I like the Polyurethane construction glues as they are fully waterproof and expand to fill any gaps. Many are now 10 minute types and are moisture activated so they can be used on a damp hull, and stick most things.
                          If you use them on dry wood you do have to give it a light misting of water from a garden sprayer.
                          #56287
                          Sm shogun
                            @smshogun38232
                            P.S. It also comes free from site.
                            #56336
                            Amy jane September
                              @amyjaneseptember49770
                              90% acetone, 10% petrol. Dissolve in enough (takes an awful lot) expanded polystyrene to make a thickish syrup.
                              Totally waterproof, fairly strong. Been using it for the last couple of years on both my model and full sized boats…
                              #56337
                                One step up from boiling down horses then?!
                                  Mixing acetone and petrol…chuck some acetone in the cars fuel tank and see the speed increase.
                                  Oh happy days
