Prop size
Prop size
Home › Forums › Beginners › Prop size
  • #61537
    Wayne Clarke
      @wayneclarke38583
      I have built an astra mm 2404 wooden offshore racer.It is fitted with a 36×50 800 watt dynamite brushless motor. I am going to use a 4000 ma 4 cell lipo battery.not sure yet what size esc but my main worry is , is a 40 mm prop too big or should I go smaller? All advice welcome, new to electric boats and i am unsure but slowly making progress
      #2526
      Wayne Clarke
        @wayneclarke38583
        #61545
        Dodgy Geezer 1
          @dodgygeezer1
          The optimum propeller for a boat is almost impossible to predict, and I find it's well worth buying a selection of cheap nylon props of different sizes so you can try out the various permutations on the lake..
          #61548
            Hi Wayne
            A 40mm prop is a good start or a 3blade 37mm.
            I started with a 800 watt(1100KV) on 3s, up it to 4s with a 40mm prop.
            Changed to 1600 watt (1450kv) on 4S with the same prop.
            Goes like it's bin stolen!!!!!
            As for ESC go for 100 amp, a bit of room to up grade the motor if required(save buying another ESC later).
