Graupner HMS HOOD Artr
Home › Forums › Beginners › Graupner HMS HOOD Artr
  • #52823
    Empire Parkstone
      @empireparkstone
      Hi does anyone have one or know the App running weight of this beast
      #2438
      Empire Parkstone
        @empireparkstone
        #52846
        Brigodoon
          @brigodoon
          Hi, don't really understand your 'App' question but, for what I know in 1940 the displacement was 48,360 Long Tons (not to be confused with 'Te' – metric tonnes) – at full battle load. hope this helps…
          Brig…
          #52847
          Empire Parkstone
            @empireparkstone
            App as in approximate and the Graupner models weight not the real thing smiley Thanks
            #52852
              Divide the weight of the real thing by the cube of the scale, multiply that by 2240 to change the model weight from tons to pounds. There is a nice calculator provided with Windows, it even does scientific for big numbers.
              #52854
              Banjoman
                @banjoman
                According to Graupner's website **LINK** the approximate weight of the ARTR HMS Hood is +/- 12 kilos. Going by the formula suggested by Malcolm Frary, this comes in a tad under scale weight, which, if I'm doing the maths correctly, should be roughly 14,5 kilos.
                /Mattias
                #52855
                  Ah, but "running operations require an additional ballast weight of approx 4Kg" so the answer is nearer 16Kg.
                  It's sad to see a once mighty modelling firm reduced to flogging Chinese plastic ARTFs which won't even be in stock until next April. Johannes G will be turning in his grave.
                  Banjoman
                    @banjoman
                    Indeed! I also saw the remark on the website about an additional 4 kg ballast weight required for running operations, although it is a tad difficult, I would say, to know how to interpret this information in conjunction with the phrase "All-up weight, approx.: 12000 g"/"Gesamtgewicht ca.: 12000 g", i.e. whether by that phrase they mean the total weight out of the box or the total weight including additional ballast … ?!
                    /Mattias
                    Edited By Banjoman on 20/10/2014 13:33:45
                    #52860
                      Point taken! I guess it's a case of slinging it into the 'oggin and seeing if it sinks – but carefully.……..
                        Sling it in, see what it looks like, decide if its setting out fully loaded or coming back empty, most of the fuel having been used, and the rum ration expended.
                        Edited By Malcolm Frary on 20/10/2014 20:51:18
