Battery Charging
Battery Charging
Home › Forums › Beginners › Battery Charging
  • #56452
    Andy C
      @andyc56856
      hi everyone
      Sort of boat related, only cause I know some of you use them. How do you charge your SLA batteries I have a 6v one, but no charging lead.
      Cheers
      Andy
      #2470
      Andy C
        @andyc56856
        Lead acid battery
        #56453
          Andy. Purchase an SLA battery charger from (for instance) Maplins, one of those simple plug in ones, 6 and 12v or get one off fleabay.
          http://www.maplin.co.uk/p/6v-sealed-lead-acid-battery-charger-500ma-lj92a
          Safest, could use something else but the dedicated charger is best.
          You know it makes sense!
            Component Shop are also very good for chargers, excellent prices too!
            Andy C
              @andyc56856
              cheers
              Thanks guys, thought about Marlins, but could not find one to fit. The plug threw me, but the ones with croc clips will work. Fiver (ish) from component shop will do it.
              Andy
              #57803
              Dodgy Geezer 1
                @dodgygeezer1
                There is something to be said for biting the bullet and buying a multi-purpose charger. Modellers are going to need the ability to charge many batteries at many different voltages.
                I bought one of these several years ago, and wouldn't be without it now. You can get similar ones from all model shops and most places on the Web:
                Andy C
                  @andyc56856
                  Bit the bullet yesterday and bought one from Howes.
                  Thought it best as I now have lead acid Niamh lipos etc, not sure about cables though. Will have to see, as the receiver pack I have had the small red connectors, deans I think.
                  Andy
                  #58057
                  Dodgy Geezer 1
                    @dodgygeezer1
                    It it's got the standard leads like an IMax B6, you should find that the basic lead is a Deans. But leads are easy enough to make up. Good price for that one…
                    #58061
                    Andy C
                      @andyc56856
                      Hi DG
                      Thought about making each lead separately, but was in my local model shop and they had a multi lead for seven pounds, so bought it and can now charge my multitude of different batteries.
                      Cheers Andy.
                      #58064
                        Just looked at the Howes link. Is it my failing eyesight or are those two different chargers pictured?
                        Andy C
                          @andyc56856
                          Hi Dave
                          Nothing wrong with your eyes. They are different. Mine is definitely the top one, maybe the otter is an older version?
                          Good charger though, easy to use.
                          Andy
                          #58115
                            When I think of all the battery chargers I have bought over the years…it does make sense to get something 1/2 decent that does several types. Hindisght/wonderful thing and all that.
                            I would get three chargers…I always need at least three batteries on a Sunday and sometimes they take a while to charge and if you leave it late/forget/do not plan ahead, you can simply run out of charging capacity.
                            This is one of the benefits of SLA`s mind.. I have more than a few models that do/can use SLA and I know I can just grab a few and off we go, as I always charge them up after a session and they hold their charge for months.
                            aSHLEY
