New project
New project
Home Forums Collectors’ corner New project
Viewing 25 posts - 1 through 25 (of 39 total)
  • #41819
      Our club also has a Del Boy character…………….Duckie!
      His greatest pleasure, is flogging all sorts of desireable gear to the club members and also ………….."Tat" …….in aid of club funds!
      Here`s his limo…….Teals Independant TraderS van……..TITS…..For short!
      I was one of his victims this week!
      A Vic Smeed Starlet in need of TLC for the outrageous sum of…..£5.00!
      I`ve always liked the quaint stuff from yesteryear, so this is my next project. Might fit a motor and no winch for novelty
      Like it, Tony?
        Ducky
          @ducky
          Got some mast's in my "tat" that might be of interest to you Bob, just trying to find out off one of the members with one of these boats the length you need!.
          "Tat" indeed!.
          Duckie.
          #41827
            Hi Bob,
            Yes! a snip at £5. Keep us posted with the restoration and conversion to r/c.
            Tony
            #41844
              Plenty of room for engines and paddle wheels.wink
                Hi, Paul
                After all the fiddling work on Glasgow, I felt like a holiday!
                The simple vintage Starlet was just the job!……and only a fiver too
                It's such a bulky boat, I could put the Slo Mo motors in and see how it behaves?
                Only hope, Vic's not watching!
                Er……Complete with coupling fan of course
                Edited By Bob Abell on 26/06/2013 08:31:20
                #41848
                LARRY WHETTON
                  @larrywhetton68737
                  Hi Bob,
                  enjoyed vidio , looked ok to me as for Starlet, built one some time ago using styrene,
                  sailed well , still sailing some whare sold it . to some body , still have plan ,
                  will buid another one day using plank on frame..best of luck with model..Larry..
                  #42002
                    Hi chaps
                    Finally have the plan from My Hobby Shop…….Delivery was about 7 days…..Excellent
                    First job…..Turn a bung on the lathe, then cast the lead
                    Kimosubby Shipyards
                      @kimosubbyshipyards
                      Hi Bob,
                      did you mean a "bung" or should that be a plug – ha ha, just seen the joke. Hope that photo has some nice text attached.  Is that blatent advertising on your ruler? Whatever next!!
                      I've just started my first plastic kit conversion, PT 109, and have put in 3 x brushless for some speed. Getting alignment proved a bit tricky but I think I'm ready to solder up the connections and run in the shafts.
                      I'll start a tread soon.
                      Kim
                      Edited By Kimosubby Shipyards on 06/07/2013 09:40:33
                      #42064
                        Thanks Kimmo
                        Just started making the plug………All great fun, turning chunks of wood in the lathe!
                        Will split the plug and use one half in plaster
                        All I need now………….Is 5lb of lead
                        There`s not much of this stuff lying around these days!
                        Ducky
                          @ducky
                          Got some for you Bob, not enough but got my ears on for some more!.
                          Duckie
                          #42068
                            Thanks Duckie
                            Won't need the gas stove in this weather?
                            It's absolutely roasting today
                              The wooden plug was great fun to turn on the lathe
                              The next job is to split the plug along the centre line to make one half of the pattern
                              In my good old engineering days at work, the patterns were painted orange and black
                              So I`ll do the same……..For old tymes sake?
                              Ducky
                                @ducky
                                What will wifey say when she discovers the newel post missing off the stairs, or did you get the wood from somewhere else?.
                                Duckie
                                #42093
                                  Hello Duckie
                                  Never mind the newel post……..What about all this sawdust?
                                  What`s that dearest?…….Oh no, there`s no dust up here, my love!……..he says with fingers crossed!
                                  I`m in for it now!………..Bob
                                  #42099
                                    The mould box and plug pattern
                                    The plug is screwed down to prevent the plug from floating in the liquid plaster
                                    #42105
                                      Hello Captain
                                      A quick question for the hard of thinking (like me) how will you prevent the plaster from sticking to the plug as it sets?
                                      Paul…Perplexed sad
                                      #42106
                                        Hello Paul
                                        For starters, the plug is painted
                                        I will probably add a coat of Vaseline too
                                        It's not much of a problem really
                                        Have you got anything on the go at the moment?
                                          Hello Bob
                                          I am busy working up the drawings for the multi superstructure hull that we discussed a few weeks ago
                                          The full cabin version worked very well as a prototype so I decided to work them all up into full drawings. At 3ft they are a little on the small side for my liking but at least I can have the prototype on the table whilst I do the detailing.
                                          How is life with you? Its a bit hot where I am.
                                            Hello Paul
                                            I had forgotten About your multi purpose hull, Paul
                                            Have you got a cross section to show us?
                                            Same here, regarding the Sun…….It's cracking' flags!
                                            Kimosubby Shipyards
                                              @kimosubbyshipyards
                                              Hi Bob,
                                              aye, you can't beat a coating of vaseline – especially as the plaster warms up as it goes off which assists the vaseline to coat the full interface!
                                              Even we've got sun here, 3 days at 24+ is a bit much, my spuds will be cooked when I lift them for supper.
                                              Like the look of the military superstructure, Paul, seems to add a sleekness to the hull.
                                              Cheers, Kim
                                              #42110
                                                Hi Bob
                                                Here is the cross section that you requested.
                                                Hi Kim
                                                Its a straight forward Perkasa but oddly enough its also the one design that I am having trouble with.
                                                #42111
                                                  Looking at the plan through the eyes of a Newbie……There is nothing shown to hold the mast up!
                                                  The mast rests on a slotted plate with two shrouds…..And that's it
                                                  Could this be the reason why the model was abandoned?
                                                  The shrouds are aft of the mast, so a cable, or rope, or sheet from the bows to mast top should do it?
                                                  Only hope there's some meat under the deck!
                                                    Hello Captain Bob
                                                    Of course there is some meat under the deck, in fact there are two great big steaks in there but I didn't want to show to much detail on the drawing (you will have noted the lack of propshafts and equipment positions)
                                                    The intention is to finalise the drawings and build some examples before publishing to raise some more money for the Royal British Legion and Help the Heroes.
                                                      Hello Paul
                                                      We seem to have got our lines crossed!
                                                      I was referring to Vic Smeads drawing with the missing mast retainers!
                                                      Not to worry…..Such is life……..lol
                                                      When are your drawings ready for publication?
