As mentioned in my last but one post I needed a bigger servo horn and because of the size it needed to be in alloy. It was a bit frustrating trying to find what I wanted which involved much browsing on Ebay and numerous suppliers, not helped by measurements not being given, even on manufacturers sites. Why is this as I consider it pretty much essential when buying aftermarket parts? Had it previously when buying motor mounts when the centres of the motor mounting holes weren't given – pretty basic really!
Anyway I found a couple of garish anodised ones on Ebay (one gold and one purple) where the size was given but really liked the look of the Fastrax ones in a much more acceptable black and looked to be well made. I know it's only a servo horn but it’s nice to do it properly! Ordered the garish ones and posted a question on a suppliers site about the size of the Fastrax one but they were slow in answering and shadow stock so I ordered one from elsewhere. Also ordered some ball-end connecters, nut and washers, partly for the build and partly for others and the spares box.
In the meantime I returned to the superstructure and started fitting the mahogany cappings to the coamings. I did have some the right width but it was a bit thick and would have been almost impossible to bend laterally to suit the curve of the cockpit and apply the tight bend where the coamings meet the deck, even with steaming and/or saw cuts. So I’m doing it in two pieces per side with one done so far.
The postman then arrived with the bits ordered, goody. The Fastrax horn is 40mm overall, so just what I wanted. I shall order another one for the Swordsman as they enable the use of stronger connecters and nicer ones! The supplier also answered my question on the dimensions of the horn as well today!
Edited By Chris Fellows on 09/02/2022 21:38:09
